"set interface" behaviour when PPP interface goes down
jorjes1984
Hi All
I have a scenario where i have a 3G connection (cellular interface) on a router
i need to do a route-map for certain traffic on this interface.
so as the interface is a PPP interface that get a dynamic IP, i cannot use the set ip next-hop command (with tracking)
so if I use the "set interface" command, to route all matching traffic to this interface, what happens if the interface goes down?
Does the routing process following this order?
1- Match access-list in route-map --> MATCH
2- check if the interface specified in the "set interface" is UP
3- If up, route the traffic through this interface
4- if down, following the default route specified on the router
is it right? or the traffic will be dropped if the interface goes down?
regards,
Mohamed Sobair
Level 7
Level 7
Yes, You are correct about all your statements.
Mohamed
