DHCP pool issue
rony999
Dear friends,
I am getting a DHCP pool issue on the Cisco 9500. Our pool has 4094 IP addresses, and the lease is for 5 days, but the user's IP is continuously changing, and because of it, they are getting connectivity issues.
Also, we have checked the pool's leased address, and it is not increasing; it is stuck at 51 lease addresses.
Please help us to resolve this issue.
14 Replies 14
Show ip dhcp server statistics
Do this multi time see if counter is increasing (share here if you can)
If counter is same then you have other dhcp server in same subnet or rogue dhcp server make this issue
MHM
Dear  MHM Cisco World
Thank you for replying.
Below is the status, and please let me know how I can check the rogue or other DHCP server.
     >...how I can check the rogue or other DHCP server.
  - By checking on the client if an address has been obtained from the intended DHCP server ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
The counter is increasing'
If lease is same ?
Do show ip dhcp binding' check if Mac (of host) add to this binding table
A- mac add but wrong IP then check your pool and GW subnet and mask
B- there is no entry' then  sure there rogue dhcp server
How can I detect it' I think best way is use wireshark
MHM
Mark Elsen
  - As the lease time is concerned ; could you check , on the client , and or with networking tools on the client (or diag)
    that the same lease time has been acquired (or observed) as it is being configured on the 9500
   M.
       Beauty and terror
      Just keep going
       No feeling is final
Can you elaborate a litte on you topology?
Are these wired/wifi  allocations, if they are wifi connections first of all I would suggest to decrease your lease from 5 days to a few hrs
Maybe post the output from the below into a txt file and attached please:
sh ip dhcp server
sh ip dhcp database
sh ip dhcp pool
sh ip dhcp conflicts
Kind Regards
Paul
Dear Paul,
Below are the details.
sh ip dhcp database (NO database)
Hello
From a client, what dhcp server does it state it received it allocation from, is that the correct server ip?
Kind Regards
Paul
Total address 4094 so mask is /20
Only check the mask in SVI use /20
MHM
rony999
Dear Team,
Please find the Wireshark screenshot.
Hi thanks for wireshark
Check IP 172.16.9.254 and mac address appear in wireshark' is it correct for your SVI IP and mac address ?
I see many request in wireshark
Under SVI use
No ip redirect
No ip unreachable
MHM
bbb bbb
Dear @rony999
In the Wireshark screenshot you provided, there is  a "DHCP NAK" info.
Pleas see link below for more information
https://www.cisco.com/c/en/us/support/docs/ip/dynamic-address-allocation-resolution/27470-100.html#:~:text=0x06,for%20configuration%20parameter.
If possible to try port mirror on the router or switch on the same subnet to see DHCP traffic on the network that will show "DHCP Offer" status just to verify DHCP server/s on the network .
Sample DHCP sniff on my terminal with my home router as DHCP server.
Happy to Help : ]
Best regards
Dear Friends,
Thank you for help.
We are able to figure out "DHCP issue". It happened because of looping somewhere in the building switch.
now we are getting different issue: "we have set the excluded ip address pool for 150 ip's but its now showing 1598 and its increasing significantly."
Below is the screenshot for reference.
Dear,
Is there any vm/device in your environment sitting on that pool that is sending multiple DHCP request? Do a packet capture file on the router by span to see devices sending multiple DHCP request and from there validate dhcp client.
https://community.cisco.com/t5/switching/how-to-check-or-debug-dhcp-request-and-ip-renew-logs/td-p/3928244
You can also try implement port security on access switch to limit mac addresses and for looping issue implement bpdu guard with its corresponding recovery mechanism.
https://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/69980-errdisable-recovery.html
lastly, how about a restart/reboot of the dhcp server (of course during maintenance window time)..?
HtH : }
Best regards,
