DHCP Pool on VLAN with PC fixed address
victorc7
I am trying to configure on a Catalyst 1000 switch a DHCP Server on network 192.168.1.0/24 with a fixed IP address of 192.168.1.10 for a PC Network with a specific MAC address.
Here is the steps I followed :
1) Type commands on Switch
conf t
ip dhcp pool 192.168.1.0
	network 192.168.1.0 255.255.255.0
	default-router 192.168.1.1
	exit
int vlan 1
	ip address pool 192.168.1.0
	exit
ip dhcp pool PC
	host 192.168.1.10
	hardware-address 01xx.xxxx.xxxx.xx
	exit
do sh ip dhcp pool
2) Check on Switch
Pool 192.168.1.0 :
 Utilization mark (high/low)    : 100 / 0
 Subnet size (first/next)       : 0 / 0
 Total addresses                : 254
 Leased addresses               : 0
 Excluded addresses             : 1
 Pending event                  : none
 1 subnet is currently in the pool :
 Current index        IP address range                    Leased/Excluded/Total
 192.168.1.1          192.168.1.1      - 192.168.1.254     0     / 1     / 254
Pool PC :
 Total addresses                : 1
 Leased addresses               : 1
 0 subnet is currently in the pool :
 192.168.1.10         192.168.1.10     - 192.168.1.10      1     / 1     / 1
3) Type commands on Switch
do clear ip dhcp binding *
4) Type commands on PC
ipconfig /release && ipconfig /renew
No IP delivered
5) Type commands on Switch
do sh interfaces
6) Check
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is XXXX.XXXX.XXXX (bia XXXX.XXXX.XXXX)
Internet address will be autoconfigured from local DHCP pool
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Last input 00:00:00, output 00:22:34, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 packets output, 0 bytes, 0 underruns
0 output errors, 2 interface resets
1704 unknown protocol drops
GigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is XXXX.XXXX.XXXX (bia XXXX.XXXX.XXXX)
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:01:18, output 00:00:00, output hang never
5 minute output rate 3000 bits/sec, 3 packets/sec
34620 packets input, 8502653 bytes, 0 no buffer
Received 4427 broadcasts (3590 multicasts)
0 watchdog, 3590 multicast, 0 pause input
62613 packets output, 37744232 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
7) Type commands on Switch
int gigabitEthernet 1/0/1
	shutdown
	no shutdown
	exit
do sh ip dhcp binding
Check
Bindings from all pools not associated with VRF:
IP address      Client-ID/              Lease expiration        Type       State      Interface
                Hardware address/
                User name
192.168.1.10     01xx.xxxx.xxxx.xx       Infinite                Manual     Selecting  Unknown
9) Type commands on PC
ipconfig /renew
No IP delivered
10) Type commands on Switch
	address 192.168.1.10 hardware-address 01xx.xxxx.xxxx.xx
% Address 192.168.1.10 is not valid in this pool.
	exit
int vlan 1
	ip address 192.168.1.2 255.255.255.0
	exit
11) Type commands on PC
ipconfig /renew
=> Got 192.168.1.3
12) Type commands on Switch and Check
(config)#do sh ip dhcp binding
Bindings from all pools not associated with VRF: IP address Client-ID/ Lease expiration Type State Interface Hardware address/ User name 192.168.1.1 XXXX.XXXX.XXXX Apr 22 2021 12:57 AM Automatic Active Vlan1 192.168.1.3 01xx.xxxx.xxxx.xx Apr 22 2021 12:58 AM Automatic Active Vlan1 192.168.1.10 01xx.xxxx.xxxx.xx Infinite Manual Selecting Unknown (config)#do sh ip dhcp pool Pool 192.168.1.0 : Utilization mark (high/low) : 100 / 0 Subnet size (first/next) : 0 / 0 Total addresses : 254 Leased addresses : 2 Excluded addresses : 1 Pending event : none 1 subnet is currently in the pool : Current index IP address range Leased/Excluded/Total 192.168.1.4 192.168.1.1 - 192.168.1.254 4 / 3 / 254 Pool PC : Utilization mark (high/low) : 100 / 0 Subnet size (first/next) : 0 / 0 Total addresses : 1 Leased addresses : 1 Excluded addresses : 1 Pending event : none 0 subnet is currently in the pool : Current index IP address range Leased/Excluded/Total 192.168.1.10 192.168.1.10 - 192.168.1.10 1 / 1 / 1
So I have an IP address but not using the one that is matching to the correct fixed pool.
31 Replies 31
Hello
If you cannot ping the rtr sourced from vlan 10 you wont be able reach the internet either, You do seem to have a valid static route on the rtr however as the switch is now correctly configured i tend to think its the rtr that's negating access.
What rtr do you have, have you tried rebooting the rtr?
Kind Regards
Paul
It is a NB6VAC modem.
I tried rebooting, redo a Routed port method with a another IP and modify Route to match but no more results.
I tried to put all clients on vlan 1 also without results.
Switch can ping 192.168.0.2 from g1/0/9 but not from other Vlan.
Router can ping 192.168.0.4 but not 192.168.1.1.
It seems they cannot access to other subnetworks.
I think my last chance is to put them on the same subnetwork.
However, I have to keep control of fixed assigned IP on the switch.
