DHCP Pool on VLAN with PC fixed address
victorc7
I am trying to configure on a Catalyst 1000 switch a DHCP Server on network 192.168.1.0/24 with a fixed IP address of 192.168.1.10 for a PC Network with a specific MAC address.
Here is the steps I followed :
1) Type commands on Switch
conf t
ip dhcp pool 192.168.1.0
	network 192.168.1.0 255.255.255.0
	default-router 192.168.1.1
	exit
int vlan 1
	ip address pool 192.168.1.0
	exit
ip dhcp pool PC
	host 192.168.1.10
	hardware-address 01xx.xxxx.xxxx.xx
	exit
do sh ip dhcp pool
2) Check on Switch
Pool 192.168.1.0 :
 Utilization mark (high/low)    : 100 / 0
 Subnet size (first/next)       : 0 / 0
 Total addresses                : 254
 Leased addresses               : 0
 Excluded addresses             : 1
 Pending event                  : none
 1 subnet is currently in the pool :
 Current index        IP address range                    Leased/Excluded/Total
 192.168.1.1          192.168.1.1      - 192.168.1.254     0     / 1     / 254
Pool PC :
 Total addresses                : 1
 Leased addresses               : 1
 0 subnet is currently in the pool :
 192.168.1.10         192.168.1.10     - 192.168.1.10      1     / 1     / 1
3) Type commands on Switch
do clear ip dhcp binding *
4) Type commands on PC
ipconfig /release && ipconfig /renew
No IP delivered
5) Type commands on Switch
do sh interfaces
6) Check
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is XXXX.XXXX.XXXX (bia XXXX.XXXX.XXXX)
Internet address will be autoconfigured from local DHCP pool
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Last input 00:00:00, output 00:22:34, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 packets output, 0 bytes, 0 underruns
0 output errors, 2 interface resets
1704 unknown protocol drops
GigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is XXXX.XXXX.XXXX (bia XXXX.XXXX.XXXX)
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:01:18, output 00:00:00, output hang never
5 minute output rate 3000 bits/sec, 3 packets/sec
34620 packets input, 8502653 bytes, 0 no buffer
Received 4427 broadcasts (3590 multicasts)
0 watchdog, 3590 multicast, 0 pause input
62613 packets output, 37744232 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
7) Type commands on Switch
int gigabitEthernet 1/0/1
	shutdown
	no shutdown
	exit
do sh ip dhcp binding
Check
Bindings from all pools not associated with VRF:
IP address      Client-ID/              Lease expiration        Type       State      Interface
                Hardware address/
                User name
192.168.1.10     01xx.xxxx.xxxx.xx       Infinite                Manual     Selecting  Unknown
9) Type commands on PC
ipconfig /renew
No IP delivered
10) Type commands on Switch
	address 192.168.1.10 hardware-address 01xx.xxxx.xxxx.xx
% Address 192.168.1.10 is not valid in this pool.
	exit
int vlan 1
	ip address 192.168.1.2 255.255.255.0
	exit
11) Type commands on PC
ipconfig /renew
=> Got 192.168.1.3
12) Type commands on Switch and Check
(config)#do sh ip dhcp binding
Bindings from all pools not associated with VRF: IP address Client-ID/ Lease expiration Type State Interface Hardware address/ User name 192.168.1.1 XXXX.XXXX.XXXX Apr 22 2021 12:57 AM Automatic Active Vlan1 192.168.1.3 01xx.xxxx.xxxx.xx Apr 22 2021 12:58 AM Automatic Active Vlan1 192.168.1.10 01xx.xxxx.xxxx.xx Infinite Manual Selecting Unknown (config)#do sh ip dhcp pool Pool 192.168.1.0 : Utilization mark (high/low) : 100 / 0 Subnet size (first/next) : 0 / 0 Total addresses : 254 Leased addresses : 2 Excluded addresses : 1 Pending event : none 1 subnet is currently in the pool : Current index IP address range Leased/Excluded/Total 192.168.1.4 192.168.1.1 - 192.168.1.254 4 / 3 / 254 Pool PC : Utilization mark (high/low) : 100 / 0 Subnet size (first/next) : 0 / 0 Total addresses : 1 Leased addresses : 1 Excluded addresses : 1 Pending event : none 0 subnet is currently in the pool : Current index IP address range Leased/Excluded/Total 192.168.1.10 192.168.1.10 - 192.168.1.10 1 / 1 / 1
So I have an IP address but not using the one that is matching to the correct fixed pool.
31 Replies 31
johnlloyd_13
Level 9
Level 9
hi,
can you use the keyword 'client-identifier' instead?
also reserve/exclude the IP for the gateway from DHCP and add DNS (and domain name if possible).
ip dhcp excluded-address 192.168.1.1
 dns-server 8.8.8.8
 host 10.10.12.10 255.255.255.0
 client-identifier 01xx.xxxx.xxxx.xx
balaji.bandi
Look at the example  to client-identifier :
https://networklessons.com/cisco/ccie-routing-switching/dhcp-static-binding-on-cisco-ios
BB
victorc7
Thanks for your replies.
It seems to be working with this commands :
conf t
ip dhcp excluded-address 192.168.1.1 192.168.1.199
	dns-server 8.8.8.8
	exit
int vlan 1
	exit
ip dhcp pool PC
	host 192.168.1.10
	client-identifier 01xx:xx:xx:xx:xx:xx
	exit
However, if I have an ISP Routeur on port 9 which provides DHCP on 192.168.0.0/24, it may take IP from this DHCP.
Issue disappear if Routeur is unplugged.
It may have a function to prevent this to happen?
how is your full configuraiton looks like now. Port 9 also taking DHCP from 1.X range ?
BB
What is the command to display full config?
i mean " show run"  so the question not answered was is the port 9 getting IP address internal DHCP ?
BB
Thanks for the command.
Here is the result :
Building configuration...
Current configuration : 4890 bytes
! Last configuration change at 16:52:10 UTC Wed Apr 21 2021
version 15.2
no service pad
hostname C1000-8P-E-2G-L
boot-start-marker
boot-end-marker
enable secret 9 XXX
no aaa new-model
switch 1 provision c1000-8p-e-2g-l
system mtu routing 1500
ip dhcp pool PC
 host 192.168.1.10 255.255.255.0
 dns-server 8.8.8.8
ip dhcp snooping vlan 1
ip dhcp snooping
ip domain-name domain.com
ip name-server 10.0.0.1
ip igmp snooping vlan 10 last-member-query-count 2
ip igmp snooping vlan 10 last-member-query-interval 1000
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
 ip dhcp snooping trust
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
 switchport mode trunk
interface GigabitEthernet1/0/10
interface Vlan1
 no ip address
ip default-gateway 192.168.1.1
ip http server
ip http banner
ip http authentication local
ip http secure-server
line con 0
line vty 0 4
 login local
 transport input all
 transport output all
line vty 5 10
 login local
 transport input all
line vty 11 15
 login
 transport input none
end
Hello
@victorc7 wrote:
ip dhcp pool PC
 dns-server 8.8.8.8
interface Vlan1
 no ip address
The switch needs to be a running a valid l3 interface and ip routing for dhcp server service to work correctly , In your configuration you don't have a valid vlan 1 ip address plus you have dhcp snooping enabled but trusting every interface which make no sense even enabling snooping in the first place also it isnt viable unless the switch is running as a layer 2 host switch.
So can you confirm if this switch SHOULD be routing for you network or do you have a router performing this function and if that is the case then the dhcp server service needs to running on the routing device and not the switch.
Kind Regards
Paul
The goal is to use ISP Router as an external Gateway, which is also used by STB, but all adressing will be made by the CISCO switch.
The switch will act as a DHCP Server and ISP Router DHCP will be ignored by other interfaces. However, if a device wants to access Internet, it will go though ISP Router.
For cost reason, I don't have any other CISCO router for the moment.
Hello
So if  the isp next-hop is 192.1681.1 you need to enable ip routing on the switch with a default route
switch
conf t
ip routing
ip route 0.0.0.0 0.0.0.0 vlan 1 192.168.1.1
int vlan 1
ip address 192.168.1 X 255.255.255.0
no shut
int x/x
description link to isp rtr
switchport host
no shut
int x/x
description link clients
switchport host
no shut
Kind Regards
Paul
I tried to adapt to my config, but it seems that I missed something.
It seems that even when using commands :
int vlan 1
	exit
It did not changed running config. So I used a fixed IP then retype the command and DHCP seems now to be pre-emptive.
However, I am still unable to get access to Internet from 192.168.1.0/24 network, which use ISP Router located on 192.168.0.2.
I does not seems like port 9 received an IP from other DHCP server.
It may be linked to the config.
#sh interface g1/0/9
GigabitEthernet1/0/9 is up, line protocol is up (connected)
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX
  Last input 00:41:36, output 00:00:00, output hang never
  5 minute input rate 178000 bits/sec, 16 packets/sec
  5 minute output rate 66000 bits/sec, 10 packets/sec
     154977 packets input, 93701466 bytes, 0 no buffer
     Received 6770 broadcasts (4213 multicasts)
     0 watchdog, 4213 multicast, 0 pause input
     138324 packets output, 34354385 bytes, 0 underruns
victorc7
Last try, but something still missing in routing in order to get Internet :
C1000-8P-E-2G-L(config)#do sh run
Current configuration : 4932 bytes
! Last configuration change at 00:08:57 UTC Thu Apr 22 2021
version 15.2
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
ip dhcp pool Netgear-WAX214
 host 192.168.1.5 255.255.255.0
ip dhcp pool PC-RJ45
ip dhcp pool PC-Wifi
 host 192.168.1.11 255.255.255.0
 dns-server 8.8.8.8
ip dhcp pool ISP
 host 192.168.0.2 255.255.255.0
ip dhcp pool Switch-192.168.0.0
 host 192.168.0.4 255.255.255.0
 client-identifier xx.xxxx.xxxx
ip dhcp snooping
ip name-server 8.8.8.8
ip name-server 8.8.4.4
interface Vlan1
ip http server
ip http banner
ip route 0.0.0.0 0.0.0.0 Vlan1 192.168.0.2
end
