Dhcp problem
frank2812
The client have a switch core Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M). In this switch the custumer  have configured a dhcp pool  for each floor as well as vlans for VoIP. But in Floor 3 the dhcp pool is only delivering 21 ip addresses from 126 ip available as you could see in the "sh ip dhcp binding" down here. You could see that the ip addreses are been leasing from the ip address 172.16.3.200 when it should be from 172.16.3.134. i hope you could help me.  I attached the sh tech from switch core and log from switch 3 from floor 3
interface Vlan50
 description Vlan VoIP Piso 3
 ip address 172.16.3.129 255.255.255.128
interface Vlan60
 description Vlan VoIP Piso 4
 ip address 172.16.4.129 255.255.255.128
ip dhcp excluded-address 172.16.3.129 172.16.3.133
ip dhcp excluded-address 172.16.4.129 172.16.4.133
ip dhcp pool VoIP-P3
   network 172.16.3.128 255.255.255.128
   domain-name seguroscanarias.com.ve
   dns-server 172.16.65.2 192.67.67.2
   default-router 172.16.3.129
   option 150 ip 172.16.65.51 172.16.65.52
ip dhcp pool VoIP-P4
   network 172.16.4.128 255.255.255.128
   default-router 172.16.4.129
sh ip dhcp binding
172.16.3.200     0100.1e7a.c470.83       Feb 24 2015 03:52 AM    Automatic
172.16.3.221     0100.1e7a.c415.75       Feb 24 2015 11:28 AM    Automatic
172.16.3.222     0100.1930.6f45.d4       Feb 24 2015 03:48 AM    Automatic
172.16.3.223     0100.1e7a.c36b.3d       Feb 24 2015 03:51 AM    Automatic
172.16.3.225     0100.1e4a.f32a.da       Feb 24 2015 04:27 AM    Automatic
172.16.3.226     0100.1e7a.26ca.bd       Feb 24 2015 03:51 AM    Automatic
172.16.3.227     0100.1e7a.c41d.04       Feb 24 2015 03:51 AM    Automatic
172.16.3.228     0100.1e7a.c40b.e9       Feb 24 2015 03:52 AM    Automatic
172.16.3.229     0100.260b.d909.51       Feb 24 2015 05:20 AM    Automatic
172.16.3.231     0100.1e7a.c36b.43       Feb 24 2015 03:50 AM    Automatic
172.16.3.232     0100.1e4a.0be1.bd       Feb 24 2015 06:38 AM    Automatic
172.16.3.233     0100.1e4a.0c3f.35       Feb 24 2015 03:52 AM    Automatic
172.16.3.234     0100.1e7a.c41d.40       Feb 24 2015 04:14 AM    Automatic
172.16.3.235     0100.1e7a.c40d.e3       Feb 24 2015 03:51 AM    Automatic
172.16.3.236     0100.1e7a.c40d.cc       Feb 24 2015 07:58 AM    Automatic
172.16.3.237     0100.1e7a.c41b.21       Feb 24 2015 07:58 AM    Automatic
172.16.3.238     0100.1e7a.c40e.7d       Feb 24 2015 03:02 AM    Automatic
172.16.3.244     0100.1e7a.c2fa.6f       Feb 24 2015 10:56 AM    Automatic
172.16.3.245     0100.1e7a.c41b.c9       Feb 24 2015 03:51 AM    Automatic
172.16.3.246     0100.1e7a.c41b.28       Feb 24 2015 10:16 AM    Automatic
172.16.3.247     0100.1e7a.c40d.c0       Feb 24 2015 03:52 AM    Automatic
Charles Hill
Is there a problem with vlan 3 not handing out ip addresses or is it just a concern that the dhcp server is not starting at 134?
I do see a couple of ip address below 200, first one being 177.
I see vlan 2 is not starting at 134 as well.
If ip addresses are not being handed out on vlan 3, i would create a monitor session on a port and look for the dhcp messages/errors.
I do see a unrelated issue in the network with a lot of speed/duplex mismatch errors on the switch.  This is probably causing a lot of slowness on these ports.  Switchport side and pc both need to be hard coded or both sides need to be auto.
CPU is extremely high as well.
ERROR: Total CPU Utilization is at 96% for the past 5 seconds, which is very
  high (>90%).
  This can cause the following symptoms:
    - Input queue drops
    - Slow performance
    - Slow response in Telnet or unable to Telnet to the router
    - Slow response on the console
    - Slow or no response to ping
    - Router doesn't send routing updates
yes in this case the problem is that vlan 50 (floor 3) is not handing out  all ip addresses from pool dhcp. the other problem is the cpu high utilization.  In the floor 3 some users are using vlan50 like you see in the show ip dhcp binding output command.
A little confused about the cisco phones that are experiencing the duplex mismatch.
Ports that are seeing some cisco ip phones are configured as trunk ports. (G4/6)
Is SEP001E7AC3FA77 one of the devices not getting an ip address?
If so try matching the speed and duplex the same on the switchport, pc and phone.  I would suspect all three devices should be set to auto.
Try
interface g4/6
switchport mode access
switchport access vlan x
switchport voice vlan 50
spanning-tree portfast
no shut
interface Mac flapping usually indicates a loop in your network.
Show spanning-tree blockedports
show spanning-tree vlan 65
This will show you what ports are forwarding and its is also where you should discover what port shouldn't be in a forwarding state which is causing the stp loop
OK  tomorrow i´ll go to the client and do all the test that you said and i´ll do some debugs
debug dhcp detail
debug ip dhcp server packet
tomorrow i´ll let you know the results
