RE: Cannot change set BAUD 115200 in CISCO2811
joluoch
Hi guys, I cannot  set BAUD 115200 in CISCO2811  or even erase contents of the flash , all I get is error like what I have in the following display.
rommon 11 >
rommon 11 > set BAUD 115200
usage: set
rommon 12 >
rommon 12 >
rommon 12 >
rommon 12 > reset
c2811 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
open(): Open Error = -13
loadprog: error - on file open
boot: cannot load "flash:c2800nm-adventerprisek9-mz.152-4.M2"
loadprog: error - Invalid image for platform
e_machine = 25, cpu_type = 135
boot: cannot load "flash:"
Entering rommon> prompt after several failed attempts to boot an IOS image.
Please check your internal/external flash drives for the correct IOS image
and issue 'reset' at the rommon> prompt to re-try the boot process.
Richard Burts
This error that shows up several times during the attempts to boot the router indicate that there is a problem with the image loaded into flash
I would guess that you have attempted to upgrade the image and copied an invalid image into flash on this router. I would think that something like tftpdnld might allow you to copy a valid image (assuming that you do have a valid image) to the router and to boot it.
Rick
Rick
Leo Laohoo
Exactly what are you trying to achieve?
If you're planning to push a correct IOS into the switch, then doing ROMmon is a very, very old, archaic and backward method.  Why?
ISR G1 and G2 (except the 800-series router) have CF slots and USB ports.  All you need to do is eject the CF, get a memory card reader and copy the IOS from a machine to the CF.  The entire copy exercise will take about 5 minutes compared to 20 minutes using ROMmon (115200 baud rate).
IF the router's bootstrap has been upgraded, you can even boot the router using the USB port.
