DHCP Relay - Site to Site VPN - Configs Posted
Mitchell Dyer
I've setup a lab environment to test a setup we are looking to deploy in the next week or so but am unable to get DHCP relay working. I've attached a diagram outlining the current setup and the configs for each device. The VPN is active and devices can ping/access one another across the tunnel but DHCP relay is not functioning.
1-0-asa Config:
: Saved
: Written by enable_15 at 21:57:03.799 UTC Mon Sep 26 2011
ASA Version 8.3(2)
hostname 1-0-asa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 10.0.0.2 255.255.255.252
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
object network NETWORK_OBJ_192.168.1.0_24
subnet 192.168.1.0 255.255.255.0
object network NETWORK_OBJ_192.168.2.0_24
subnet 192.168.2.0 255.255.255.0
object network obj-10.0.0.2
host 10.0.0.2
object network obj-192.168.1.0
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip host 10.0.0.2 host 10.3.3.2
access-list outside_1_cryptomap extended permit ip host 192.168.1.1 host 192.168.2.11
pager lines 24
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-635.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_192.168.1.0_24 NETWORK_OBJ_192.168.1.0_24 destination static NETWORK_OBJ_192.168.2.0_24 NETWORK_OBJ_192.168.2.0_24
nat (outside,inside) static 192.168.1.6
nat (outside,inside) static 192.168.1.0
route outside 0.0.0.0 0.0.0.0 10.0.0.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
http redirect inside 80
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group5
crypto map outside_map 1 set peer 10.3.3.2
crypto map outside_map 1 set transform-set ESP-AES-256-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption aes-256
hash sha
group 5
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcprelay server 192.168.2.11 outside
dhcprelay enable inside
dhcprelay setroute inside
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
tunnel-group 10.3.3.2 type ipsec-l2l
tunnel-group 10.3.3.2 ipsec-attributes
pre-shared-key cisco123
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:304261141a85c2d11d5b7bd338381cc4
: end
2-0-asa Config:
: Saved
: Written by enable_15 at 22:22:33.209 UTC Mon Sep 26 2011
ASA Version 8.3(2)
hostname 2-0-asa
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.3.3.2 255.255.255.252
ftp mode passive
host 10.0.0.2
access-list outside_1_cryptomap extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip host 192.168.2.11 host 10.0.0.2
access-list outside_1_cryptomap extended permit ip host 192.168.2.11 host 192.168.1.1
pager lines 24
mtu inside 1500
mtu outside 1500
no failover
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_192.168.2.0_24 NETWORK_OBJ_192.168.2.0_24 destination static NETWORK_OBJ_192.168.1.0_24 NETWORK_OBJ_192.168.1.0_24
route outside 0.0.0.0 0.0.0.0 10.3.3.1 1
http server enable
http 192.168.2.0 255.255.255.0 inside
http authentication-certificate inside
crypto map outside_map 1 set peer 10.0.0.2
encryption aes-256
hash sha
group 5
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
tunnel-group 10.0.0.2 type ipsec-l2l
tunnel-group 10.0.0.2 ipsec-attributes
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
call-home
profile CiscoTAC-1
no active
Cryptochecksum:ecda5162ededc8b3ee469fa0328f5e53
: end
Any help is greatly appreciated.
Mitchell Dyer
Solved!
ASA with DHCP server on inside interface:
On ASA with DHCP server on INSIDE interface, the crypto map to the remote ASA add entries for the DHCP Server IP  to both remote ASA inside and outside interface.
On ASA with DHCP server on INSIDE interface, nat exempt the DHCP Server IP Address to both remote ASA inside and outside interface.
Remote ASA:
On remote ASA in the crypto map to ASA with DHCP server on INSIDE interface, add entries for the inside and outside interface to the DHCP Server IP.
On remote ASA nat exempt the outside interface to the DHCP Server.
Cryptomap ACL on ASA1-0 should look like this:
access-list outside_1_cryptomap extended permit ip host 10.0.0.2 host 192.168.2.11
NAT exemptions on ASA1-0 Should look like this:
object network obj-192.168.1.0_24
object network obj-192.168.2.0_24
     host 10.0.0.2
object network dhcp-server
     host 192.168.2.11
nat (inside,outside) source static obj-192.168.1.0_24 obj-192.168.1.0_24 destination static obj-192.168.2.0_24 obj-192.168.2.0_24
nat (outside,outside) source static obj-10.0.0.2 obj-10.0.0.2 destination static dhcp-server dhcp-server
Cryptomap ACL on ASA2-0 should look like this:
     host 192.168.2.11
object network remote-asa-int
     host 192.168.1.1
object network remote-asa-out
     host 10.0.0.2
nat (inside,outside) source static obj-192.168.2.0_24 obj-192.168.2.0_24 destination static obj-192.168.1.0_24 obj-192.168.1.0_24
nat (inside,outside) source static dhcp-server dhcp-server destination static remote-asa-int remote-asa-int
nat (inside,outside) source static dhcp-server dhcp-server destination static remote-asa-out remote-asa-out
