DHCP relay with ASR-9000
bo.bayles
I'm having a problem getting DHCP working with an ASR9k as shown in this document. I've successfully implemented very similar setups with some Cisco IOS routers, but the IOS XR on the ASR seems to be defeating me.
I have:
  • Router A (happens to be a 3750)
  • A DHCP/BOOTP/TFTP server, connected to router A
  • Router B - this is the ASR, running software version 4.0.3.
  • Router A and B are connected by a layer-3 link.
  • Router C (happens to be a Broadcom embedded router). It's connected to Router B by a VLAN trunk link.
  • Device 1, this one needs to get its configuration by DHCP/BOOTP/TFTP. It's connected to Router C by a VLAN trunk link.
  • Device 2, this one doesn't need any DHCP/BOOTP/TFTP. It's connected to Router C by a VLAN trunk link (its port is the same as Device 1's)
Device 2 works great - it can ping the DHCP/BOOTP/TFTP server (and vice versa) and everything else it needs.
Device 1 is the problem - I can't get it to receive BOOTP replies from the DHCP/BOOTP/TFTP server.
The ASR is configured like this:
ASR Configuration
interface GigabitEthernet0/2/0/8
description MCH Port 0/15
interface GigabitEthernet0/2/0/8.77 l2transport
description MCH Port 0/15, VL77 trunk
encapsulation dot1q 77
rewrite ingress tag pop 1 symmetric
interface BVI77
ipv4 address 172.18.162.241 255.255.255.248
ipv4 directed-broadcast
l2vpn
bridge group IRB
  bridge-domain Vlan77
   routed interface BVI77
dhcp ipv4
profile LAB_VIDEO_SDM relay
  helper-address vrf default 172.18.161.10
interface BVI77 relay profile LAB_VIDEO_SDM
interface GigabitEthernet0/2/0/8.77 relay profile LAB_VIDEO_SDM
The problem is strange. When Device 1 reboots it sends a DHCP request. This is forwarded to the TFTP server as expected - I can see the BOOTP Requests at that server (confirmed with tcpdump). I can also see the BOOTP Replies leave that server (confirmed with monitor session on Router A). However, those BOOTP replies are never broadcast to the Vlan77 devices - those packets never show up on Router C (confirmed with monitor session).
What might cause such behavior? I have tried various options like enabling forward-protocol udp 67 and forward-protocol udp 68 with no change in behavior.
I hope this picture will illustrate the setup:
0 Replies 0
