DHCP Relay won't work on a Virtual-Template Interface
Liam Ferguson
Hope you can help me out
I am trying to achieve the following scenario
These two parts are working
PPP user --> LNS Router -->Radius
Radius --> LNS Router
I am having trouble getting this part working
LNS Router --> DHCP Relay
interface Loopback2
 ip address 10.10.10.10 255.255.255.0
interface Virtual-Template1
 ip unnumbered Loopback2
 ip helper-address 1.1.1.1
 ip mtu 1400
 ip tcp adjust-mss 1360
 peer default ip address dhcp
 ppp mtu adaptive
 ppp authentication pap chap
 ppp chap hostname router1
 ppp ipcp dns 2.2.2.2 3.3.3.3
end
With the above config, my debug dhcp detail looks something like this
Feb 22 14:04:58.191: DHCP: SDiscover attempt # 1 for entry:
Feb 22 14:04:58.191: DHCP: SDiscover: sending 285 byte length DHCP packet
Feb 22 14:04:58.191: DHCP: SDiscover 285 bytes
Feb 22 14:04:58.191:             B'cast on Port-channel1.122 interface from 10.10.10.10
Feb 22 14:04:58.191:             B'cast on Port-channel2.312 interface from 10.10.10.10
Note: Why would this DHCP Request be broadcast on two other Layer 3 interfaces when in theory it should be only broadcast on the 10.10.10.0/24 subnet?? Neither Port-channel1.122  or Port-channel1.312 are in the 10.10.10.0/24 subnet
The DHCP server (1.1.1.1) isn't showing up in the debugs and there are only mentions of Broadcast so I suspect the DHCP is being generated (using this command  peer default ip address dhcp) but the helper address command isn't converting it to unicast.
Any ideas and feedback would be very helpful
Thank you in advance
5 Replies 5
do you see the same behavior when you configure the virtual template with 'virtual profile if-needed' ?
What is the output of 'show interfaces virtual-access' ?
Hi Georg
Thanks for the replay. I added that command but I am still seeing the same issue.
Virtual Access 1 is down  but 2 is up
Virtual-Access2 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100000 usec,
  Encapsulation PPP, LCP Closed
  Base PPPoVPDN vaccess
  Vaccess status 0x44, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 5 seconds on reset
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 5w0d
  Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     176962 packets input, 61890325 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     381334 packets output, 159289892 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
Liam
Hello Liam,
try to configure 'ip directed-broadcast' on the virtual template.
Hi Georg
Thank you
Just tried that but it's still sending out the Broadcast DHCP instead of directed unicast
Liam
Liam Ferguson
I found a way to get this working.
When the interface sub commands wouldn't work, I turned to global commands instead.
What I did was create a global reference to a dhcp server using
ip dhcp-server 1.1.1.1
After this, the DHCP request was no longer broadcasted out. It went out as a directed unicast and I picked up an IP OK
Just to follow it through though I removed the
command and it still worked proving that the global command overrules the ip helper in this case.
Thanks Georg for your help on this
Any other suggestions still welcome as to how this can be done under the interface and not globally
Liam
