02-04-2006 12:47 AM - edited 03-03-2019 11:38 AM
We're plannin to have a cisco 7206VXR router with NPE-G1. we're also planning to have a DS3 line for WAN connection to a remote corporate site.
What port adapter i'm going to use for the said WAN connection?
Thanks in advance!
udimpas
Solved! Go to Solution.
02-04-2006 02:27 AM
Either of the following would do the job for you:
PA-A3-T3 1-Port ATM Enhanced DS3 Port Adapter
PA-A6-T3 1Port Enh ATM DS3 Port Adapter(8kVCs)
Hope that helps - pls rate the post if it does.
Paresh
02-04-2006 02:27 AM
Paresh
02-04-2006 11:39 PM
Simplest thing is to use PA-T3 clear channel DS3 card. This will provide you with a point-to-point serial connection. Just assign a /30 and you should be good to go.
good luck!
