DHCP server from CORP VRF can server dhcp clients on PUBLIC VRF ?
bipinchandra
Hi Guys,
I am trying to set up a lab a dhcp pool in a DHCP server where my dhcp server is located in CORP VRF and clients are in PUBLIC VRF. And there is no route leaking between the VRFs. Will it work ?? From Theory with Option 82 enabled it works but in my lab it does not work. I could see the dhcp server provides dhcp offer to the client but client never gets the IP.
Will be very appreciated if someone could help
bipinchandra
I have got the solution. It is working fine without VRF leaking. key points are we need to use " ip DHCP relay information option vpn" on Core switch. DHCP server must be aware of VRF's.
Below is the Configuration of Core, WAN and DHCP server for the GNS3 lab snapshot I have attached.
CORE#sh run
Building configuration...
hostname CORE
boot-start-marker
boot-end-marker
ip vrf CORP_VRF
rd 100:1
ip vrf GUEST_VRF
rd 300:1
ip vrf IOT_VRF
rd 200:1
ip dhcp relay information option vpn
no ip domain-lookup
ip cef
no ipv6 cef
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Loopback1
ip vrf forwarding CORP_VRF
ip address 2.2.2.2 255.255.255.255
interface Loopback2
ip vrf forwarding IOT_VRF
ip address 3.3.3.3 255.255.255.255
interface Loopback3
ip vrf forwarding GUEST_VRF
ip address 4.4.4.4 255.255.255.255
interface Ethernet0/0
no switchport
ip address 11.11.11.2 255.255.255.254
interface Ethernet0/1
no switchport
ip address 11.11.11.4 255.255.255.254
interface Ethernet0/2
no switchport
ip address 11.11.11.0 255.255.255.254
interface Ethernet0/3
no switchport
ip address 11.11.11.6 255.255.255.254
interface Ethernet1/0
switchport access vlan 100
switchport mode access
interface Ethernet1/1
switchport access vlan 200
interface Ethernet1/2
switchport access vlan 300
interface Ethernet1/3
switchport access vlan 400
interface Vlan100
ip address 10.10.10.1 255.255.255.0
ip helper-address 100.100.100.100
ip helper-address global 100.100.100.100
interface Vlan200
interface Vlan300
interface Vlan400
ip address 10.10.20.1 255.255.255.0
router bgp 6500
bgp router-id 1.1.1.1
bgp log-neighbor-changes
redistribute connected
neighbor 11.11.11.7 remote-as 6900
address-family ipv4 vrf CORP_VRF
bgp router-id 2.2.2.2
neighbor 11.11.11.1 remote-as 6900
neighbor 11.11.11.1 activate
exit-address-family
address-family ipv4 vrf GUEST_VRF
bgp router-id 4.4.4.4
neighbor 11.11.11.5 remote-as 6900
neighbor 11.11.11.5 activate
exit-address-family
address-family ipv4 vrf IOT_VRF
bgp router-id 3.3.3.3
neighbor 11.11.11.3 remote-as 6900
neighbor 11.11.11.3 activate
exit-address-family
DHCP#sh run
Current configuration : 2508 bytes
! Last configuration change at 05:42:23 UTC Thu Jan 4 2024
version 15.2
service compress-config
hostname DHCP
no ip icmp rate-limit unreachable
ip vrf CORP_VRF
rd 100:1
ip vrf GUEST_VRF
rd 300:1
ip vrf IOT_VRF
rd 200:1
ip dhcp excluded-address 10.10.20.1 10.10.20.10
ip dhcp excluded-address vrf CORP_VRF 10.10.10.1 10.10.10.10
ip dhcp excluded-address vrf GUEST_VRF 10.10.10.1 10.10.10.20
ip dhcp excluded-address vrf IOT_VRF 10.10.10.1 10.10.10.30
ip dhcp pool CORP
vrf CORP_VRF
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
lease 0 0 5
ip dhcp pool IOT
vrf IOT_VRF
lease 0 0 5
ip dhcp pool GUEST
vrf GUEST_VRF
lease 0 0 5
ip dhcp pool GLOBAL
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
lease 0 0 5
interface Loopback0
ip address 100.100.100.100 255.255.255.255
no switchport
ip address 11.11.11.9 255.255.255.254
no switchport
ip address 11.11.11.13 255.255.255.254
interface Vlan1
no ip address
shutdown
router bgp 6000
bgp router-id 100.100.100.100
neighbor 11.11.11.8 remote-as 6900
neighbor 11.11.11.12 remote-as 6900
end
DHCP#
WAN#sh run
Current configuration : 3058 bytes
hostname WAN
ip vrf CORP_VRF
rd 100:1
ip vrf GUEST_VRF
rd 300:1
ip vrf IOT_VRF
rd 200:1
interface Loopback0
ip address 11.11.11.11 255.255.255.255
interface Loopback1
ip address 22.22.22.22 255.255.255.255
interface Loopback2
ip address 33.33.33.33 255.255.255.255
interface Loopback3
ip address 44.44.44.44 255.255.255.255
no switchport
ip address 11.11.11.3 255.255.255.254
no switchport
ip address 11.11.11.5 255.255.255.254
no switchport
ip address 11.11.11.1 255.255.255.254
no switchport
ip address 11.11.11.7 255.255.255.254
no switchport
ip address 11.11.11.8 255.255.255.254
no switchport
ip address 11.11.11.12 255.255.255.254
shutdown
interface Vlan1
no ip address
shutdown
router bgp 6900
bgp router-id 11.11.11.11
neighbor 11.11.11.6 remote-as 6500
neighbor 11.11.11.9 remote-as 6000
bgp router-id 22.22.22.22
neighbor 11.11.11.0 remote-as 6500
neighbor 11.11.11.0 activate
neighbor 11.11.11.13 remote-as 6000
neighbor 11.11.11.13 activate
exit-address-family
bgp router-id 44.44.44.44
neighbor 11.11.11.4 remote-as 6500
neighbor 11.11.11.4 activate
exit-address-family
bgp router-id 33.33.33.33
neighbor 11.11.11.2 remote-as 6500
neighbor 11.11.11.2 activate
exit-address-family
end
WAN#
9 Replies 9
balaji.bandi
 PUBLIC VRF  - you mean global VRF or VRF name it self PUBLIC
And there is no route leaking between the VRFs  - if there is no leaking there do not know the routing aware of each other, so they become disjoin entity. so that does not work.
Option 82 enabled  - only take place when the router able to reach remote end IP, if that is not known how that options works ?
BB
It seems working in Juniper network. What is the difference we have with Cisco and Juniper.. ?? I can share Juniper caps if anyone is interested in investigating it ....!!!
without VRF leaking it not work
but if client in VRF and DHCP in global it work we use it in MPLS
hostname R2-PE2
interface Loopback0
interface FastEthernet0/0
ip vrf forwarding BLUE
ip address 11.0.0.1 255.255.255.0
ip helper-address global 200.0.0.5
duplex full
interface Serial3/3
ip address 200.0.0.2 255.255.255.0
mpls ip
serial restart-delay 0
router ospf 100
network 2.2.2.2 0.0.0.0 area 0
network 200.0.0.0 0.0.0.255 area 0
hostname R5-P-DHCP
ip dhcp pool VRF-RED
vrf RED
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
ip dhcp pool BLUE
vrf BLUE
network 11.0.0.0 255.255.255.0
default-router 11.0.0.1
interface Serial3/0
ip address 100.0.0.5 255.255.255.0
mpls ip
interface Serial3/3
ip address 200.0.0.5 255.255.255.0
mpls ip
router ospf 100
network 100.0.0.0 0.0.0.255 area 0
Thank You for your response. But what makes MPLS works and not between normal vrfs?. Let me test your solution and update you.
My question is still why MPLS makes it work?. Will vxlan set up work then??
Why MPLS? The dhcp with id vpn is not use only for mpls' but using in mpls is so common because mpls use PE with vrf and mpls core is global' so we use dhcp with id vpn to assing IP from pool in global rib.
MHM
bipinchandra
In my set up. it seems working. I have clients in Red VRF and BLUE VRF gets IP from the DHCP server from global .
Why is it working here ??
Below is the config of switch where DHCP pool is configured.
DHCP#sh run
Current configuration : 2039 bytes
! Last configuration change at 17:26:01 UTC Tue Dec 19 2023
version 15.2
hostname DHCP
boot-start-marker
boot-end-marker
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console discriminator EXCESS
no aaa new-model
ip vrf BLUE
rd 200:1
ip vrf RED
rd 100:1
vrf RED
ip dhcp pool BLUE
vrf BLUE
no ip domain-lookup
ip cef
no ipv6 cef
spanning-tree mode pvst
interface Loopback0
ip address 20.20.20.20 255.255.255.255
interface Ethernet2/0
interface Ethernet2/1
interface Ethernet2/2
interface Ethernet2/3
interface Ethernet3/0
interface Ethernet3/1
interface Ethernet3/2
interface Ethernet3/3
interface Vlan1
no ip address
interface Vlan100
ip vrf forwarding RED
ip address 10.0.0.1 255.255.255.0
ip helper-address global 20.20.20.20
interface Vlan200
ip forward-protocol nd
ip tcp synwait-time 5
ip http server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
DHCP#
The ip helper dhcp is vrf aware
So you can use
Ip helper-address global
Or
Ip helper-address vrf x
So try same your lab and make dhcp pool in router reach via other vrf abd use (vrf x)
And check.
MHM
bipinchandra
CORE#sh run
hostname CORE
boot-start-marker
boot-end-marker
ip vrf CORP_VRF
rd 100:1
ip vrf GUEST_VRF
rd 300:1
ip vrf IOT_VRF
rd 200:1
no ip domain-lookup
ip cef
no ipv6 cef
interface Loopback0
interface Loopback1
interface Loopback2
interface Loopback3
no switchport
no switchport
no switchport
no switchport
interface Vlan100
interface Vlan200
interface Vlan300
interface Vlan400
router bgp 6500
exit-address-family
exit-address-family
exit-address-family
DHCP#sh run
version 15.2
hostname DHCP
ip vrf CORP_VRF
rd 100:1
ip vrf GUEST_VRF
rd 300:1
ip vrf IOT_VRF
rd 200:1
ip dhcp pool CORP
vrf CORP_VRF
lease 0 0 5
ip dhcp pool IOT
vrf IOT_VRF
lease 0 0 5
ip dhcp pool GUEST
vrf GUEST_VRF
lease 0 0 5
ip dhcp pool GLOBAL
lease 0 0 5
interface Loopback0
no switchport
no switchport
interface Vlan1
no ip address
shutdown
router bgp 6000
end
DHCP#
WAN#sh run
hostname WAN
ip vrf CORP_VRF
rd 100:1
ip vrf GUEST_VRF
rd 300:1
ip vrf IOT_VRF
rd 200:1
interface Loopback0
interface Loopback1
interface Loopback2
interface Loopback3
no switchport
no switchport
no switchport
no switchport
no switchport
no switchport
shutdown
interface Vlan1
no ip address
shutdown
router bgp 6900
exit-address-family
exit-address-family
exit-address-family
end
WAN#
I already use it in my lab I share before, but I think I missing command when copy from gns3 to here
you need
sure otherwise how local DHCP know which DHCP local pool it use
it match the VRF send in relay with what you config under the DHCP pool
anyway this my mistake I must sure I copy all commands I use in lab
glad you get the idea in end
happy new year and have a nice day
MHM
