DHCP Snooping
Ashish Shah
Community Member
Since past few days I'm facing issue of rouge DHCP broadcast in my company network so I planned to deploy DHCP Snooping on my LAN environment. For this I implemented DHCP snooping on one switch on test basis to see the result. Below are the commands that i configured on my switch.
Global Configuration:
ip dhcp snooping
ip dhcp snooping vlan 1 4094 ••> I have intentionally allowed all the vlan’s as after eSNA we will be allowing all the vlans on trunk interface.
ip dhcp snooping information option
ip dhcp snooping verify mac-address
Interface Configuration:
(config-if)# ip dhcp snooping trust ••> Only on the interface which is uplink port or where DHCP server is connected. Rest all interfaces remains as untrust by default.
I also kept trunk port, channel-ports as trusted ports.
But unfortunately as soon as i deployed this configuration users were not able to receive ip from DHCP server and when i removed this configuration it was back to normal.
I repeat I have deployed this switch only on one access switch.
Can anyone help me understand what went wrong in my configuration and what should i take care to avoid failure. Thanks in advance. I'm waiting for reply and help.
Thanks!
Ashish Shah
2 Accepted Solutions
Latchum Naidu
The configuration looks ok but can you remove "ip dhcp snooping verify mac-address" command and see.
See the below configration what i have.
ciscoswitch(config)# ip dhcp snooping
ciscoswitch(config)# ip dhcp snooping vlan number 100
ciscoswitch(config)# ip dhcp snooping vlan number 10-15 100 110
ciscoswitch(config)# ip dhcp snooping information option
ciscoswitch(config)# interface fa0/0
ciscoswitch(config-if)# ip dhcp snooping trust
ciscoswitch(config-if)# ip dhcp snooping limit rate 202
ciscoswitch# show ip dhcp snooping
DHCP Snooping is configured on the following VLANs:
    10-15 100 110
Insertion of option 82 information is enabled.
Interface           Trusted        Rate limit (pps)
FastEthernet2/1     yes            10
FastEthernet2/2     yes            none
FastEthernet3/1     no             20
ciscoswitch# show ip dhcp snooping binding
MacAddress      IP Address      Lease (seconds)      Type        VLAN      Interface
0000.0100.0201  10.0.0.1        1600                 dynamic     100       FastEthernet2/1
Please click on the correct answer if this answered your question.
Naidu.
Hi Ashish,
Where "202" indicates that the interface can receive "202" messages per second
Configures the number of DHCP packets per second (pps) that an interface can receive.
Note: You may not want to configure untrusted rate limiting to more than 100 pps.
Normally, the rate limit applies to untrusted interfaces. If you want to set up rate limiting for trusted interfaces, keep in mind that trusted interfaces aggregate all DHCP traffic in the switch, and you will need to adjust the rate limit to a higher value.
Naidu.
7 Replies 7
Latchum Naidu
    10-15 100 110
Naidu.
Thanks for your input.
I'm trying to use and configure below command and do proof of concept before final roll-out. I will revert back if any help required for the same.
Thanks!
Ashish
Thank you sir solve my broblem
See as you have enabled dhcp snooping, you can also use its binding table to enable DAI to prevent arp spoofing also
ip arp inspection vlan xx
int faxx
ip arp inpsection trust
res
Paul
Kind Regards
Paul
Hi Ashish,
Is that helped you.
Naidu.
Thanks it is working for me.
I will be deploying this in one of Production switch and observe.
I have one more query as in what command statement " ip dhcp snooping limit rate 202 "  stands for?
Ashish
Hi Ashish,
Naidu.
