Dialer Interface - High Total Output Drops
cheonghomtai
Can someone give me some links to Dialer Interface info?
I have some issues with my Dialer 1, having lots of Total drops.
My internet connection is broadband (10 Mbps) using fiber,
interface Dialer1
description *** DIALER-1 GROUP-11 POOL-111 ***$FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
ip virtual-reassembly max-reassemblies 512
zone-member security ZONE-3
encapsulation ppp
ip tcp adjust-mss 1460
dialer pool 111
dialer idle-timeout 0
dialer persistent
dialer-group 11
ppp authentication chap pap callin
ppp chap hostname xxxx
Here's the output:
ISR2811#sh int dialer 1
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Description: *** DIALER-1 GROUP-11 POOL-111 ***$FW_OUTSIDE$
  Internet address is 2xx.xx.xx.161/32
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 1/255, rxload 8/255
  Encapsulation PPP, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi3
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 2w2d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 56468
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 42 kilobits/sec
  5 minute input rate 58000 bits/sec, 1 packets/sec
     29068998 packets input, 1586452367 bytes
     15238816 packets output, 18446744072203736053 bytes
Bound to:
Virtual-Access3 is up, line protocol is up
  Hardware is Virtual Access interface
     reliability 255/255, txload 4/255, rxload 8/255
  Encapsulation PPP, LCP Open
  Listen: CDPCP
  Open: IPCP
  PPPoE vaccess, cloned from Dialer1
  Vaccess status 0x44, loopback not set
  Interface is bound to Di1 (Encapsulation PPP)
  Last input 00:00:05, output never, output hang never
  Input queue: 0/75/1/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     29228665 packets input, 1588587279 bytes, 1 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     15238850 packets output, 2789157092 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
Virtual-Access1            unassigned      YES unset  down                  dow
Virtual-Access2            unassigned      YES unset  up                    up
Virtual-Access3            unassigned      YES unset  up                    up
Dialer1                    2xx.xxx.xxx161   YES IPCP   up                    up
Question:
1 - Why is there 3 Virtual Access?
2- Virtual Access 3 is bound to dialer 1, what about VA2 and VA1?
Thanks again.
18 Replies 18
  Hardware is Unknown
  Description: *Dialer-1 Grp-11 Pool-111
  Internet address is 219.92.xx.xx/32
     reliability 255/255, txload 1/255, rxload 31/255
  Last clearing of "show interface" counters 1w5d
  Input queue: 0/75/2/0 (size/max/drops/flushes); Total output drops: 17126
  Output queue: 0/400/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
  5 minute input rate 7000 bits/sec, 5 packets/sec
     7947196 packets input, 407557182 bytes
     5529591 packets output, 1083071615 bytes
Bound to:
     reliability 255/255, txload 27/255, rxload 36/255
  Listen: CDPCP
  Open: IPCP
  Last input 00:00:03, output never, output hang never
  5 minute input rate 8000 bits/sec, 3 packets/sec
  5 minute output rate 6000 bits/sec, 4 packets/sec
     8078430 packets input, 409290857 bytes, 0 no buffer
     5529608 packets output, 1083074657 bytes, 0 underruns
Still no luck.
Trying to think how to reset everything from scratch.
Under dialer inteface configure, "WGR1(config-if)#hold-queue 1024 out" and then check if you see any improvements.
That didn't work at all.
So been playing with different version of IOS.
Apparently, it router had some "Out-Of-Order Segment with ip ident 0"
And i read what others mentioning that 12.4T does support OOOS.
After trying few 15.x version, i had to settle for this
c2800nm-advsecurityk9-mz.150-1.M10.bin which seems to have solved the issue.
None of the 12.4X IOS worked.
  Hardware is Unknown
  Internet address is 219.92.x.x /32
     reliability 255/255, txload 91/255, rxload 255/255
  Encapsulation PPP, LCP Closed, loopback not set
  Last clearing of "show interface" counters 08:34:53
  Output queue: 0/1024/64/0 (size/max total/threshold/drops)
  5 minute input rate 501000 bits/sec, 78 packets/sec
  5 minute output rate 20000 bits/sec, 26 packets/sec
     447454 packets input, 262798999 bytes
     296740 packets output, 36018187 bytes
