Dialer PPPOE / I can't access internet / Help
Rodrigo Bezerra
I can't access internet through the router
Could someone help get ip, but not out to internet
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
load-interval 30
dialer pool 1
dialer idle-timeout 0
dialer persistent
ppp chap hostname itestet@terra.com
ppp chap password 7 000000087817878242E30
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1 name TESTE
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         192.168.5.33    YES NVRAM  up                    up
GigabitEthernet0/1          unassigned      YES NVRAM  up                    up
Dialer1                           201.67.111.65   YES IPCP   up                    up
Virtual-Access1               unassigned      YES unset  up                    up
Virtual-Access2               unassigned      YES unset  up                    up
Lima#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, Dialer1
S     128.70.0.0/16 [1/0] via 192.168.107.214
      192.168.5.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.5.32/28 is directly connected, GigabitEthernet0/0
L        192.168.5.33/32 is directly connected, GigabitEthernet0/0
      192.168.107.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.107.192/27 is directly connected, GigabitEthernet0/0
L        192.168.107.193/32 is directly connected, GigabitEthernet0/0
      200.204.210.0/32 is subnetted, 1 subnets
C        200.204.210.248 is directly connected, Dialer1
      201.67.111.0/32 is subnetted, 1 subnets
C        201.67.111.65 is directly connected, Dialer1
show pppoe  session
     1 client session
Uniq ID  PPPoE  RemMAC          Port                    VT  VA         State
           SID  LocMAC                                      VA-st      Type
    N/A   1622  0090.1aa0.3275  Gi0/1                  Di1  Vi2        UP
                30f7.0d45.91a1                              UP
#traceroute 8.8.8.8
Tracing the route to 8.8.8.8
VRF info: (vrf in name/id, vrf out name/id)
  1  *  *  *
  2  *  *  *
  3  *  *  *
5 Replies 5
Subeh Sharma
Hi Rodrigo,
Shut the dialer interface and please get the output of the following:
-'debug ppp negotiation'
- 'debug pppoe event'
After you enable the above, no shut the dialer and collect the logs for about 10-20 seconds. Then disable the logs by 'undebug all'
Subeh
antonio.guirado
Level 3
Level 3
Hi Rodrigo,
your pppoe connection is established so debug ppp is not needed:
Besides, your default route is to Dialer1:
I do not know if your router still has ip address 201.67.111.65 but I can ping it:
ping 201.67.111.65
PING 201.67.111.65 (201.67.111.65) 56(84) bytes of data.
64 bytes from 201.67.111.65: icmp_req=1 ttl=40 time=330 ms
64 bytes from 201.67.111.65: icmp_req=2 ttl=40 time=329 ms
64 bytes from 201.67.111.65: icmp_req=3 ttl=40 time=329 ms
Please, can you post the "ping 8.8.8.8 source dialer1" output?.
Regards.
philip daly
I have this probelm too
I'm currently having an issue getting an internet conection on a cisco 881 router. I can get a WAN IP on Dialer 1 but i cant ping the dialer interface or any www addresses (e.g 8.8.8.8). Can any one see from the below config where the issue might be?? the conection is PPPOE with PAP authentication.
In the config you will see cellular 0 configed. That works fine and i have it shut down.
Current configuration : 2140 bytes
! Last configuration change at 02:38:55 UTC Fri Jan 10 2014
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
ip name-server 139.130.4.4
no ipv6 cef
vpdn enable
chat-script INTERNET ""ATDT*98*4# TIMEOUT 60 "CONNECT"
license udi pid CISCO881G-K9 sn FHK1451758Y
controller Cellular 0
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 2
interface Cellular0
ip nat outside
ip virtual-reassembly in
encapsulation ppp
shutdown
dialer in-band
dialer string INTERNET
dialer-group 1
async mode interactive
ppp chap refuse
ppp pap sent-username XXXXXX password 0 XXXXXX
interface Vlan1
ip address 192.168.1.254 255.255.255.0
ip nat inside
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
dialer persistent
dialer-group 2
ppp authentication pap callin
ppp chap refuse
no ip http server
ip nat inside source list 1 interface Cellular0 overload
ip nat inside source list 2 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Cellular0 10
logging esm config
access-list 1 permit any
access-list 2 permit any
dialer-list 1 protocol ip list 1
dialer-list 2 protocol ip list 2
control-plane
line con 0
no modem enable
line aux 0
line 3
exec-timeout 0 0
script dialer INTERNET
login
modem InOut
no exec
transport input all
transport output all
speed 237000
line vty 0 4
login
transport input all
End
ip int brief
Cellular0                  unassigned      YES NVRAM  administratively down down
Dialer1                    144.131.219.241 YES IPCP   up                    up
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4              unassigned      YES NVRAM  up                    up
NVI0                       unassigned      YES unset  administratively down down
Vlan1                      192.168.1.254   YES NVRAM  up                    up
Router#show pppoe session
     1 client session
    N/A   2692  0090.1a42.b2bd  Fa4                    Di1  Vi1        UP
                e05f.b99c.1d96                              UP
Can you try this:
ip access-list standard NAT
permit 192.168.1.0 0.0.0.255
route-map NAT-Dialer
match ip add NAT
match interface dialer 1
route-map NAT-Cellular
match ip add NAT
match interface Cellular0
no ip nat inside source list 1 interface Cellular0
no ip nat inside source list 2 interface dialer1
ip nat inside source route-map NAT-Cellular interface Cellular0
ip nat inside source route-map NAT-Dialer interface dialer1
Alain
Ashish Arora
Can you please try to perform following:-
1. Remove the highlighted command:-
interface Dialer1
mtu 1492
ip nat outside  --- remove the command for testing purpose.
encapsulation ppp
dialer pool 2
dialer persistent
dialer-group 2
ppp chap refuse
2. After removing the command , please run "clear interface dialer1", this command will initiate a new PPP session.
3. wait for some time to establish a session , once new ip address will be assigned , now try to ping 4.2.2.2 , 8.8.8.8,4.2.2.3 and see if that works.
The reason why i am saying to remove the command is because when we try to NAT whole subnet(ip any any ) defined in ACL 1 , it might create issues to the ICMP/Telnet traffic.Alternatively you can define the local subnet(permit ip x.x.x.x y.y.y.y) in the access-list if you don't want to remove the command.
Hope this would be helpful:-
https://supportforums.cisco.com/message/4135617#4135617
