Dialer watch-list
kuldeep.kaur
Hi Guys,
On one of our router we have a frame-relay link and a isdn back up link. We use dialer watch-list. Please find below the configuration.
interface BRI0/0/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
isdn point-to-point-setup
ppp authentication chap
ppp multilink
interface Dialer0
bandwidth 128
ip address 10.x.x.x x.x.x.x
encapsulation ppp
dialer pool 1
dialer remote-name xxxxxxxxx
dialer idle-timeout 300
dialer string xxxxxxxxxx
dialer hold-queue 30
dialer watch-disable 60
dialer watch-group 1
dialer-group 1
ppp multilink
ppp multilink load-threshold 3 either
dialer watch-list 1 ip 10.206.0.0 255.255.252.0
dialer watch-list 1 ip 10.252.248.39 255.255.255.255
show ip route:
B 10.252.248.39/32 [20/0] via
The problem is when the primary link is back up the isdn line did not disconnect automatically. Is it a bug in the IOS. On this router we are running version 12.4 (3b).
Rgds
spremkumar
Level 9
Level 9
Can you post your full config here ?
regds
kuldeep.kaur
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 10.x.x.x 255.255.255.0
ip pim dense-mode
no snmp trap link-status
h323-gateway voip bind srcaddr 10.x.x.x
interface BRI0/0/0
description ISDN backup to Sydney
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1/0:0
description Access link to BT MPLS 512K
bandwidth 512
no ip address
encapsulation frame-relay IETF
frame-relay fragment 397 end-to-end
frame-relay lmi-type ansi
max-reserved-bandwidth 95
service-policy output customer_cos
interface Serial0/1/0:0.101 point-to-point
description PVC to BT MPLS 512K
bandwidth 512
ip unnumbered Loopback0
frame-relay interface-dlci 101
class FRTS
interface Serial0/2/0:23
description PSTN PCCW +852 0700-0999
no ip address
isdn switch-type primary-net5
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
This is the main config on the router plus the earlier which I have posted.
Tks
How long you are seeing your isdn active ?
I think it should be active for 5minutes based even after the primary comes up thats because of the idle timeout configured over there.
Is it possible to reduce the same to least possible value which you feel can suit your enviroment and check ?
regds
Hi Mate,
If you dont shut down the interface it will remain up for ever. I have see this earlier also for another customer and the isdn bills were huge. Any work around.
Tks
