difference between int vlan100 and vlan100 configs
lcaruso
Level 6
Level 6
What's the difference between creating vlans like this?
interface vlan100
ip address ....
vlan 100
name test
ip address...
Thanks.
2 Accepted Solutions
Roman Rodichev
Level 7
Level 7
the int vlan100 creates  layer3 interface for routing
it requires creation of layer 2 vlan first, which is created with
vlan100 command
(there should not be "ip address" option here)
layer3 interface is not required unless you need to route
vlan 100
name test
You are creating a VLAN instance in the VLAN database.
Roman Rodichev
Level 7
Level 7
vlan100 command
thanks. I must have been running some pretty old code. I was doing static routing with only the int vlan100 commands being used.
vlan 100
name test
that explains this message...I never created the vlan100 artifact before creating the int vlan100
Switch(config-if)#switchport access vlan 100
% Access VLAN does not exist. Creating vlan 100
Thanks!
