Difference between NAT and access-list on ASA and ISR Router
williamk
Hi, am replacing an ASA with a Cisco ISR router. The context of the nat rules and access rules are a little different, so want to make sure I am translating them correctly. Access rules are for incoming traffic on the WAN interface. Relevant configs are shown below. I did not write the ASA rules, so have no idea why they used port ranges, or why they did both TCP and UDP.  So I cleaned up the port ranges and left it as allowing both TCP and UDP on the router. Did I translate correctly?
--ASA CONFIG--
object network GWMobile2
host 192.168.200.79
nat (any,any) static 1.1.1.1
access-list WAN_access_in extended permit object-group TCPUDP any4 object GWMobile2 object-group GWMobile object-group protocol TCPUDP protocol-object udp protocol-object tcp object-group service GWMobile tcp-udp port-object range 3102 3102 port-object range 8120 8120 group-object Internet object-group service Internet tcp-udp description HTTP port-object eq www port-object range 443 443 --ISR Router config ---- ip nat inside source static 192.168.200.79 1.1.1.1 ip access-list extended OUTtoIN_ACL permit object-group GWMobile_Service any host 192.168.200.79 Service object group GWMobile_Service tcp-udp eq 3102 tcp-udp eq 8120 tcp-udp eq 80 tcp-udp eq 443
7 Replies 7
Hello
Try the below interpretations:
access-list 100 permit tcp host 192.168.200.79 any eq 3102
access-list 100 permit tcp host 192.168.200.79 any eq 8120
access-list 100 permit tcp host 192.168.200.79 any eq www
access-list 100 permit tcp host 192.168.200.79 any eq 443
access-list 100 permit udp host 192.168.200.79 any eq 3102
access-list 100 permit udp host 192.168.200.79 any eq 8120
route-map TST permit 10
match ip address 100
ip nat inside source static 192.168.200.79 1.1.1.1 route-map TST
or
ip nat inside source static tcp 192.168.200.79 80 1.1.1.1 80 extendable
ip nat inside source static tcp 192.168.200.79 443 1.1.1.1 443 extendable
ip nat inside source static tcp 192.168.200.79 3102 1.1.1.1 3102 extendable
ip nat inside source static udp 192.168.200.79 3102 1.1.1.1 3102 extendable
ip nat inside source static tcp 192.168.200.79 8120 1.1.1.1 8120 extendable
ip nat inside source static udp 192.168.200.79 8120 1.1.1.1 8120 extendable
Kind Regards
Paul
Hello again Paul,
I have not been able to test my configuration on a live router yet, so not sure if my nat and access-list will work or not on the ISR Router.  Is there something wrong with my proposed ISR config?  I noticed you are using route maps and not using service groups.  Your way is probably better, I am just trying to understand why.  I need to choose a way and stick with it as I translate all the NAT rules and access rules from the ASA to the ISR.
Hello @williamk
I dont see any relation with your object-group, acl and your nat statement!
However Its late in day here and i'm a bit punchy so maybe another review would be required but at this time as far as i can see that is the interpretation i got  from the asa config your posted.- I have provided two possible options but could there be others?
Kind Regards
Paul
Hi Paul,
You are correct, in my ISR config, there is no direct relation between the ACL and the NAT statement.  It is the same way on the ASA.  My understanding on the ASA is that the two are seperate, but of course one won't work with out the other.  So on the ISR then is it better to use a route map tied to an ACL, or can I just do it like it was done on the ASA, with seperate NAT statements, and a ACL on the WAN interface that allows the incoming traffic that will be translated to the inside IPs?  Just trying to discern best practice here, if there is one.
Hello
If you look closely with the ASA config there is indeed a relation with the access-list and object groups, the two suggested configs I posted for the asr would both work>
Personally the route-map is more elegant option.
Kind Regards
Paul
OK, got it.  So if I use your second NAT solution:
Will the following access-list work with that?  I have a zone based firewall with an ACL that allows incoming traffic on the WAN interface:
tcp-udp eq 3102
tcp-udp eq 8120
tcp-udp eq 80
tcp-udp eq 443
If I am correct this ACL is saying allow any ip to hit 192.168.200.79 on the destination ports in the GWMobile_Service group.
Hello
Nat will work providing your iOS fw allows outside initiation of traffic towards its public /internet host
Kind Regards
Paul
