Basic EBGP Question
laxmicisco
DO i need to add the default route towards my upstream BGP peers when establishing the EBGP peer ??
Jon Marshall
You should not need to use a default route.
Normally EBGP peers are directly connected so no need for a route at all but if the peers are multiple L3 hops away from each other then on your peer you would need a static route for the peer IP address and a valid next hop IP so your BGP router knows how to reach the peer IP address.
Jon
Deepak Kumar
As if your EBGP peer is not directly connected then you need a static route. The BGP is not trusting on the default route. The same question I asked in this week and faced the same issue as I have a default route can reach the remote peer but neighborship was not happening.
Be aware that if BGP is not directly connected then it also required ebgp-multihop commands additional to configuration.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
