Difference between QoS and HQoS with configuration level
s76602061
Please teach what is difference between QoS and HQoS with configuration level.
Below site explains that the definition of QoS and HQoS but there is no example
of configuration. Please teach if you have information.
https://supportforums.cisco.com/sites/default/files/legacy/5/9/1/15376195-ISR_G2_Perfomance.pdf
QoS
When testing QoS, packets are marked for classification
by the packet generator, and the router under test
classifies the packets based on the markings.
H-QoS
HQoS uses a parent policy, usually a bandwidth shaper,
and subsequent child policies to color and queue
traffic within the parent policy.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
policy-map child
class x
priority percent 30
class y
bandwidth remaining percent 60
class class-default
bandwidth remaining percent 40
policy-map parent
class class-default
service-policy child
shape average #
interface x
service-policy output parent
The parent policy shapes the traffic at some rate and the child policy determine how queued shaped traffic is processed.
Thank you for your comment
Sorry Joseph, am not getting your explanation ditto the question
Okay, what part of "Below site explains that the definition of QoS and HQoS but there is no example of configuration." don't you understand?  I believe the request is for a sample configuration, agree?
If not, how do you understand OP?
I provided an example of a HQoS policy implemented on an interface.  Certainly possible, I didn't provide enough explanatory remarks.
