Enabled DHCP in my router to get IP's but unable to get IP's.
thirumg3
PFA for your reference
in SW
interface FastEthernet0/1
switchport trunk allowed vlan 1,10,20
switchport mode trunk
interface FastEthernet0/2
switchport access vlan 10
interface FastEthernet0/3
switchport access vlan 20
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
ROUTER
p dhcp excluded-address 10.1.10.1 10.1.10.99
ip dhcp excluded-address 10.1.20.1 10.1.20.99
ip dhcp pool VLAN10
network 10.1.10.0 255.255.255.0
default-router 10.1.10.1
dns-server 10.1.10.1
ip dhcp pool VLAN20
network 10.1.20.0 255.255.255.0
default-router 10.1.20.1
dns-server 10.1.20.1
17 Replies 17
thirumg3
SW0:
switchport mode access
duplex full
speed 100
duplex full
speed 100
interface Vlan1
ip address 172.1.0.5 255.255.255.224
banner motd ^C***********WARNING**************
THIS SWITCH GOING TO DOWN ON SATUDAY FOR SERVICE^C
access-list 1 permit host 172.1.0.2
line con 0
login local
line vty 0 4
access-class 1 in
login local
BRANCH:
Current configuration : 1822 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Branch
enable secret 5 xxx
ip dhcp excluded-address 10.1.10.1 10.1.10.99
ip cef
no ipv6 cef
username xxx secret 5 xxx
license udi pid xxx sn xxx
ip ssh version 2
ip domain-name cisco.com
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.1.1.1 255.255.255.0
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 10.1.10.1 255.255.255.0
ip helper-address 172.1.0.62
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 10.1.20.1 255.255.255.0
interface FastEthernet0/0.30
no ip address
ip address 209.165.201.11 255.255.255.224
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router rip
ip classless
ip route 172.1.0.32 255.255.255.224 172.1.0.33
ip route 0.0.0.0 0.0.0.0 172.1.0.32
ip route 172.1.0.32 255.255.255.252 172.1.0.66
ip route 0.0.0.0 0.0.0.0 209.165.201.12
ip flow-export version 9
banner login ^C****************warning**************
unathuraized to login this device only autherized person can login^C
line con 0
login local
line aux 0
line vty 0 4
access-class 1 in
login local
transport input ssh
transport output none
line vty 5
access-class 1 in
login local
transport input ssh
line vty 6 15
access-class 1 in
login
ntp server 172.1.0.62
end
HQ:
hostname HQ
enable secret 5 xxx
ip dhcp excluded-address 172.1.0.1 172.1.0.66
ip dhcp pool WAN
network 172.1.0.0 255.255.255.224
default-router 172.1.0.66
ip cef
no ipv6 cef
ip ssh version 2
ip address 209.165.201.12 255.255.255.224
ip access-group NO_WEB in
duplex auto
speed auto
ip address 172.1.0.33 255.255.255.224
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 172.1.0.1
ip route 0.0.0.0 0.0.0.0 172.1.0.65
ip route 172.1.0.0 255.255.255.252 172.1.0.1
ip route 172.1.0.0 255.255.255.224 172.1.0.65
ip route 172.1.0.0 255.255.255.224 172.1.0.67
ip route 10.1.10.0 255.255.255.0 209.165.201.11
ip route 10.1.20.0 255.255.255.0 209.165.201.11
ip access-list extended NO_WEB
deny tcp host 172.1.0.3 host 172.1.0.62 eq www
permit ip any any
line con 0
login local
line aux 0
line vty 0 4
access-class 1 in
login local
transport input telnet
transport output ssh
line vty 5
access-class 1 in
login local
line vty 6 15
login
ntp authentication-key 1 md5 0822455D0A16 7
ntp authenticate
ntp server 172.1.0.62 key 1
end
DHCP SERVER:
balaji.bandi
You need to post the Router full config, - since we see basic config of switch, as trunk and allowed VLAN in the Trunk, but we have not see same config is applied on the router side ?
BB
Router#sh runn
Building configuration...
Current configuration : 1161 bytes
version 15.1
hostname Router
ip dhcp pool VLAN10
ip dhcp pool VLAN20
ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn xxx
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Switch#sh runn
Current configuration : 1242 bytes
version 15.0
hostname Switch
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Check have you created vlan 10, 20 ?
from switch post below output :
show vlan
show interface status
Router :
show ip interface brief
show ip route
show ip dhcp server statistics
show ip dhcp pool
show ip sockets
below reference guide :
https://www.computernetworkingnotes.com/ccna-study-guide/configure-dhcp-server-for-multiple-vlans-on-the-switch.html
BB
*show vlan:*
Switch>en
Switch#sh vlan
VLAN Name Status Ports
1 default active Fa0/4, Fa0/5, Fa0/6, Fa0/7
Fa0/8, Fa0/9, Fa0/10, Fa0/11
Fa0/12, Fa0/13, Fa0/14, Fa0/15
Fa0/16, Fa0/17, Fa0/18, Fa0/19
Fa0/20, Fa0/21, Fa0/22, Fa0/23
Fa0/24, Gig0/1, Gig0/2
10 VLAN0010 active
20 VLAN0020 active
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
10 enet 100010 1500 - - - - - 0 0
20 enet 100020 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
*show interface status:*
Switch#show int status
Port Name Status Vlan Duplex Speed Type
Fa0/1 connected trunk auto auto 10/100BaseTX
Fa0/2 connected trunk auto auto 10/100BaseTX
Fa0/3 connected trunk auto auto 10/100BaseTX
Fa0/4 notconnect 1 auto auto 10/100BaseTX
Fa0/5 notconnect 1 auto auto 10/100BaseTX
Fa0/6 notconnect 1 auto auto 10/100BaseTX
Fa0/7 notconnect 1 auto auto 10/100BaseTX
Fa0/8 notconnect 1 auto auto 10/100BaseTX
Fa0/9 notconnect 1 auto auto 10/100BaseTX
Fa0/10 notconnect 1 auto auto 10/100BaseTX
Fa0/11 notconnect 1 auto auto 10/100BaseTX
Fa0/12 notconnect 1 auto auto 10/100BaseTX
Fa0/13 notconnect 1 auto auto 10/100BaseTX
Fa0/14 notconnect 1 auto auto 10/100BaseTX
Fa0/15 notconnect 1 auto auto 10/100BaseTX
Fa0/16 notconnect 1 auto auto 10/100BaseTX
Fa0/17 notconnect 1 auto auto 10/100BaseTX
Fa0/18 notconnect 1 auto auto 10/100BaseTX
Fa0/19 notconnect 1 auto auto 10/100BaseTX
Fa0/20 notconnect 1 auto auto 10/100BaseTX
Fa0/21 notconnect 1 auto auto 10/100BaseTX
Fa0/22 notconnect 1 auto auto 10/100BaseTX
Fa0/23 notconnect 1 auto auto 10/100BaseTX
Fa0/24 notconnect 1 auto auto 10/100BaseTX
Gig0/1 notconnect 1 auto auto 10/100BaseTX
Gig0/2 notconnect 1 auto auto 10/100BaseTX
*Router
*show ip interface brief:*
Router#sh ip interface brief
FastEthernet0/0 unassigned YES unset up up
FastEthernet0/0.1 10.1.10.1 YES manual up up
FastEthernet0/0.2 10.1.20.1 YES manual up up
FastEthernet0/0.3 10.1.1.1 YES manual up up
FastEthernet0/1 unassigned YES unset administratively down down
Vlan1 unassigned YES unset administratively down down
*show ip route:*
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
C 10.1.1.0/24 is directly connected, FastEthernet0/0.3
L 10.1.1.1/32 is directly connected, FastEthernet0/0.3
C 10.1.10.0/24 is directly connected, FastEthernet0/0.1
L 10.1.10.1/32 is directly connected, FastEthernet0/0.1
C 10.1.20.0/24 is directly connected, FastEthernet0/0.2
L 10.1.20.1/32 is directly connected, FastEthernet0/0.2
*show ip dhcp pool:*
Router#show ip dhcp pool
Pool VLAN10 :
Utilization mark (high/low) : 100 / 0
Subnet size (first/next) : 0 / 0
Total addresses : 254
Leased addresses : 0
Excluded addresses : 2
Pending event : none
1 subnet is currently in the pool
Current index IP address range Leased/Excluded/Total
10.1.10.1 10.1.10.1 - 10.1.10.254 0 / 2 / 254
Pool VLAN20 :
10.1.20.1 10.1.20.1 - 10.1.20.254 0 / 2 / 254
*show ip dhcp server statistics & show ip sockets
*Try to get this information but am getting error.*
Router#show ip sockets
% Invalid input detected at '^' marker.
Router#show ip dhcp server satistics
^% Invalid input detected at '^' marker.
M02@rt37
Hello @thirumg3
On your router:
R1(config)#service dhcp
Best regards
thirumg3
facing the same issue and getting APIPA.
Router>en
Router#config t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#service DHCP
Router(config)#exit
Router#
%SYS-5-CONFIG_I: Configured from console by console
Router#wr
[OK]
Router#sh runn
version 15.1
hostname Router
ip dhcp pool VLAN10
ip dhcp pool VLAN20
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
ok @thirumg3
do the vlan 10 and 20 are created on the switch ?
sh vlan brief
Best regards
Switch>en
Switch#sh vlan
10 VLAN0010 active
20 VLAN0020 active
Remote SPAN VLANs
show ip dhcp server statistics <<- share this
thirumg3
Branch#sh ip dhcp server statistics
M02@rt37
Hello @thirumg3
Thanks for the config.
On SW please only config [switchport mode access] and [switchport access vlan 10] on interface FastEthernet0/2 - do [no switchport  mode trunk].
Same thing on interface FastEthernet0/3 ; config [switchport mode access] and [switchport access vlan 20]  - do [no switchport  mode trunk].
Also you cas add [spanning-tree portfast] command on Fa0/2 and Fa0/3.
Your FastEthernet0/1 seem to be your trunk link towards the router. Config is ok !
Also on the Router interface face to face with the Switch, the config ROAS is ok!
interface Fa0/0
description --To_SW
no shut
interface Fa0/0.10
description --Vl10
encapsulation dot1q 10
ip add 10.1.10.1 255.255.255.0
no shut
interface Fa0/0.20
description --Vl20
encapsulation dot1q 20
ip add 10.1.20.1 255.255.255.0
no shut
Please do [show ip int brief] on router and give us the output.
Best regards
Switch#config t
Switch(config)#int f0/2
Switch(config-if)#switchmode access vlan 10
Switch(config-if)#switch mode access vlan 10
Switch(config-if)#switch access vlan 10
Switch(config-if)#no switch mode trunk
Command rejected: An interface must be configured to the Access or Trunk modes to be configured to NoNegotiate.
Switch(config-if)#no switchport mode trunk
Switch(config-if)#exit
Switch(config-if)#
Switch(config-if)#spanning-tree portfast
%Warning: portfast should only be enabled on ports connected to a single
host. Connecting hubs, concentrators, switches, bridges, etc... to this
interface when portfast is enabled, can cause temporary bridging loops.
Use with CAUTION
%Portfast has been configured on FastEthernet0/2 but will only
have effect when the interface is in a non-trunking mode.
Branch#sh ip int brief
FastEthernet0/0 unassigned YES manual up up
FastEthernet0/0.1 10.1.1.1 YES manual up up
FastEthernet0/0.10 10.1.10.1 YES manual up up
FastEthernet0/0.20 10.1.20.1 YES manual up up
FastEthernet0/0.30 unassigned YES unset up up
FastEthernet0/1 209.165.201.11 YES manual up up
