DMVPN Spoke not connecting when using starlink
Wizard4777
I have set up as above. I am using starlink at one of my spokes. I am not able to get to pass VPN traffic even though show dmvpn shows that the vpn is up.
Wizard4777
I have resolved this issue by just removing the tunnel interface and pasting the same config back recreating the tunnel interface.
15 Replies 15
Share
Show dmvpn detail
In spoke you have issue with
MHM
On the hub, I can see that the tunnel is up but I am unable to ping the Spoke tunnel IP: 172.29.255.201
I have a single hub and multiple spokes but with this spoke, i want to use to ISP and one is starlink. I created two tunnels on spoke and used shared tunnel protection. one tunnel for the other ISP and one tunnel for starlink, both to be connected to the single tunnel dmvpn hub.
post the running configs of your hub and spoke routers...
only one router is affected when connection is pushed through starlink. when pushed through other ISP no issues. so config is definitely not the issue.
post the spoke config anyway, as we do not know what you have configured (Phase 1/2/3, which underlying routing, etc.), we may spot something. Starlink uses TCP spoofing optimization; if you use the default policy, you are also dealing with CGNAT. Are you using a 100.64.0.0/10 IP address (which means you are using the default policy) ?
flags is DN meaning dyanimc NAT
And the claimed IP appear' this good indication that hub detect behind NAT spoke'
Last steps is you need to use
Ipsec transfers AH no ESP
Also you need to use trabsport mode not tunnel mode.
MHM
does that mean i change the hub also to AH? using transport mode
In spoke add AH and transport
In Hub add AH only as second ipsec trans'
This make hub work with spoke use esp and spoke use AH with transport
MHM
can you provide me a sample config for this? i don't seem to get what you mean.
Hub config
Crypto ipsec trans spoke1 esp-
Mode tunnel
Crypto ipsec trans AH-
Mode transport
In Spoke1 (behind NAT)
Mode transport
In Spoke2 (not behind NAT)
Crypto ipsec trans ESP-
Mode tunnel
MHM
Thank you. I will keep this for future reference
Wizard4777
without AH and transport ??
MHM
