Difference between vrf lite and vrf
Hello all,
Is there any difference between vrf lite and vrf????
can i configure both on cisco ISR router 4331 ?
any content of vrf or vrf lite is welcome.
Thanks!!!!!
8 Replies 8
Mark Elsen
 - FYI : https://www.pynetlabs.com/vrf-full-form-in-networking/#:~:text=VRF%20Lite%20is%20a%20subset,making%20VRF%20Lite%20very%20simple.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi @Mark Elsen,
i went through it earlier but not got the lab part .....
I will ask you something here to explain
R1-R2
in R1 and R2 there are many same VRF, and there is one link between R1 and R2, how we config this Link??
Hi @MHM Cisco World,
as i think we can do it after making subinterfaces on the physical interfaces..
if we have 100 VRF ? how many subinterface?
if you not use VRF-lite you need 100 subinterface each one have it IP
with VRF-lite
you need one interface IP and you can add 100 VRF to this link with one IP.
that is the different.
Joseph W. Doherty
"Is there any difference between vrf lite and vrf????"
Yes, the "lite" version often does not have the "capacity" or all the "features" of the non-lite version.  For example, lite might not support as many VRF instances and/or might not support VRF using MPLS.
