Ripv2 dynamic routing on packet tracer
kuzukaan
Hey Guys,
So i must do dynamic routing with the protocol RIPv2 on the packet tracer. I can't find the issue. Notebook 1 can communicate with Router1 only not Router2 and Provider2. Notebook 2 can communicate with Router 1 such as Router 2 and Provider1, but there is like on IP on Provider1, like if i Ping from Notebooj 2 to the IP it does communicate, but with a 50% Packetloss. Deactivated on RIPv2 the no-auto summary too.
You can find the file below
Thanks in advance
the left router, Router1, did not have
no ip routing
configured. After enabling
ip routing
you have full connectivity. Attached the revised file...
11 Replies 11
post your zipped Packet Tracer project (.pkt) file, and include any passwords if you have those configured...
Hey,
files types like .pkt are not supported, if i drag the file.
you need to zip the file. You can use a free program like 7-Zip.
Router Passwords are Cisco
no ip routing
ip routing
balaji.bandi
Looking at your picture - Router 1 and Router 2 both network statement is 10.0.0.0 ?
Ignore my old comment  - Can you post on Router 1
show IP route
BB
I was thinking like the same, but i'll try and inform if it worked out
It didn't work
But if i try to type like the 10.0.10.10/24 to R3 it assigns it to 10.0.0.0/24 even if wrote 10.0.10.10/24. Should I try to change the 10.0.10.10/24 IP -Address.
ignore my old comment, can you post
show IP router
from Router 1 and Router 2 and Service provider1 (make sure IP routing enabled in all routers)
They should learn both the routes from RIP
coming to your original post -
Notebook 1 can communicate with Router1 only not Router2 and Provider2 (I take this as provider 1)
if the Router 1 Learning routes from Router2 and Provider 1 - they should be able to ping each other.
check the is all the interfaces up,
Notebook 1 - use traceroute to check where the packets dropping.
Note : last couple of post we seen end device also have FW, so disable when you pinging notebook to notebook
BB
