Difference between WS-X6K-SUP2-2GE and WS-X6K-S2U-MSFC2 sup model
ccnp_ccie
need help,
can anybody tell me the diffrence between and WS-X6K-SUP2-2GE and WS-X6K-S2U-MSFC2 sup model and can i use both the model in cisco 6509 switch in RPR+ mode(Redundancy)using native OS.
Akash
purohit_810
Level 5
Level 5
Both are supporting 6509.
Check below link, Table-2.
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a00800887fd.html
RPR+ support by all supervisor engines but that future specefic on IOS version.
Dharmesh Purohit
thanks for reply,
i have same ios on both the sup card, can i used both of them same time on cisco 6509 switch using RPR+.
thanks & Regards
Akash
Edison Ortiz
You sure can, both Supe Models are the same. The part number is different because one was built before 2001. The post-2001 model contains 256MB DRAM on the Supe and 256MB DRAM on the MSFC
http://www.cisco.com/warp/public/473/151.html#topic3
[edit]
Found another link where it states the default memory has changed to 512MB on MSFC
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_bulletin0900aecd8017a5e7.html
HTH,
