Difference of filtering routes between using interface and control-plane
yangfrank
Hi All
Any one can give me suggestion to understand the difference of filtering routes between using interface and control-plane?
I read the document, please see the link http://www.ciscozine.com/copp-what-is-that/
We also can use ACL and attach it in interface to filter routes, why we use control-plane ? Thank you !
Jon Marshall
Two completely different things.
CoPP is used to protect the control plane of a device and make sure it does not become overloaded if a lot of packets are sent to the device's IP address.
You can use it to prioritise certain traffic such as routing updates and give a low priority to other packets.
It is not used to filter routing updates.
Jon
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Besides the logical difference, as already described by Jon, on switches, interface filtering might be programed into the ASICs while CoPP filtering might not be.
