Redundancy Configure in WAN connectivity
kumareshm1980
       I want to configure redundant link (Failover) for my WAN conectivity with two different provider.Can anybody guide me the best method  about this configuration ?
Ashok Kumar
Which type setup you want make?
If the Primary/Secondary Link setup, then go for floating default static route configuration
1. Create IP SLA /TRACK for both route
2. Use AD value to select the primary/secondary route
3. Command
ip route 0.0.0.0 0.0.0.0 <next-hop ip address> track <no.> 100 (AD value)
- Ashok
Please rate the useful post or mark as correct answer as it will help others looking for similar information
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
For selecting a "best method", need more information.  However, in general, often dynamic routing is used to deal with loss and restoration of WAN connectivity.
