Different network addresses ssid
Ed Lo
I want to make multiple SSID and want them all to have different network addresses. So all of them have different ip address ranges they give to the devices connected to them. Do I need to make a DHCP pool for each vlan assigned to an SSID?
thank you
from what I can tell, you need to bridge the Vlans on the internal interface. Check the changes I made in bold:
Current configuration : 3675 bytes
version 12.4
no service pad
hostname ap
no aaa new-model
dot11 syslog
dot11 ssid batman
vlan 2
authentication open
mbssid guest-mode
dot11 ssid robin
vlan 3
authentication open
mbssid guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid batman
ssid robin
antenna gain 0
mbssid
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.1
encapsulation dot1Q 2
ip address 192.168.12.1 255.255.255.0
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
interface GigabitEthernet0.2
encapsulation dot1q 2
no ip route-cache
bridge-group 2
interface GigabitEthernet0.3
encapsulation dot1q 3
no ip route-cache
bridge-group 3
ip http server
no ip http secure-server
ip http help-path
line con 0
privilege level 15
login local
no activation-character
line vty 0 4
login local
cns dhcp
end
8 Replies 8
Hello Ed,
SSID is associated with the VLAN, not with the DHCP pool. If you need a different SSID for each VLAN, you just configure the DHCP pools for each VLAN, and then associate the SSID with the respective VLANs.
What hardware/devices are you trying to configure ?
I'm using a cisco 1941w router and I was wondering if I needed to configure the dhcp pools for each vlan so that their respective SSID have different ip ranges.
Ed,
yes. For each VLAN, a different DHCP pool, and then you can associate the SSIDs with the respective pools.
Sorry, but you wouldn't happen to know the commands for associating a vlan with a dhcp pool would you? I've tried it on my own but when i connect to that ssid it doesn't give me an ip address.
Using an ssid named batman and vlan 2
This is my current config if it helps:
Current configuration : 1880 bytes
! Last configuration change at 19:07:35 UTC Thu Jul 27 2017
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ip dhcp excluded-address 192.168.12.1
ip dhcp excluded-address 192.168.12.0
ip dhcp pool batmanpool
import all
network 192.168.12.0 255.255.255.0
domain-name batman.com
default-router 192.168.12.1
dns-server 4.4.4.2 4.4.4.1
lease 7
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
interface wlan-ap0
ip unnumbered Vlan1
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Wlan-GigabitEthernet0/0
switchport mode trunk
no ip address
interface Vlan1
ip address 10.10.0.30 255.255.255.0
interface Vlan2
interface Vlan4
no ip address
ip forward-protocol nd
ip http server
ip http authentication aaa
access-list 11 permit 0.0.0.1 255.255.255.0
control-plane
line con 0
line aux 0
line 2
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
Ed,
your DHCP pool to VLAN mapping/configuration is fine. How did you associate the SSID with the VLAN ? Have a look at the document below (this is for an Aironet, but it should work in a similar fashion):
https://supportforums.cisco.com/document/55561/multiple-ssid-multiple-vlans-configuration-example-cisco-aironet-aps
actually the link to the previous post I sent you has an even better sample configuration (again, scroll down to Lukasz Bromirski's post):
https://supportforums.cisco.com/discussion/10927121/cisco-1941w-basic-configuration
I took a look at that example and I did do it the way they show there but still nothing. I noticed that it mentions that the vlan have to be configured on the local switch but the router isn't connected to one so I've never seen the edge(config)# that it mentions.
Below is the config of the router from the ap# point of view. I don't know if you see anything wrong but it's not working right now so no ip is assigned when I connect a device to that SSID.
version 12.4
no service pad
hostname ap
no aaa new-model
dot11 syslog
dot11 ssid batman
vlan 2
authentication open
mbssid guest-mode
dot11 ssid robin
vlan 3
authentication open
mbssid guest-mode
bridge irb
no ip address
no ip route-cache
ssid batman
ssid robin
antenna gain 0
mbssid
station-role root
bridge-group 1
no ip route-cache
bridge-group 2
no ip route-cache
bridge-group 3
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
ip http help-path
bridge 1 route ip
line con 0
privilege level 15
login local
line vty 0 4
login local
cns dhcp
end
version 12.4
no service pad
hostname ap
no aaa new-model
dot11 syslog
dot11 ssid batman
vlan 2
authentication open
mbssid guest-mode
dot11 ssid robin
vlan 3
authentication open
mbssid guest-mode
bridge irb
no ip address
no ip route-cache
ssid batman
ssid robin
antenna gain 0
mbssid
station-role root
bridge-group 1
no ip route-cache
bridge-group 2
no ip route-cache
bridge-group 3
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip route-cache
bridge-group 2
no ip route-cache
bridge-group 3
ip http server
ip http help-path
line con 0
privilege level 15
login local
line vty 0 4
login local
cns dhcp
end
