Different types of tunnels
Robert Craig
Level 3
Level 3
Can one router terminate a SVTI in addition to being a DMVPN hub? It seems like when I turn on the DMVPN interface, the SVTI tunnel disconnects itself.
Peter Paluch
Robert,
Can you post a configuration of both interfaces and a description or a configuration of the resulting routing? I suspect more that after you start the DMVPN, the routing changes in such a way that it influences the destination of the SVTI.
Best regards,
Peter
No problem. As you can see below, Tunnel 1 is the SVTI to the spoke. The minute I 'no shut' Tunnel 5, I lose the connection through Tunnel 1. I am using OSPF, but even when I had static routes, it failed.
Hub side
interface Tunnel1
bandwidth 5000
bandwidth receive 2000
ip address 10.10.10.1 255.255.255.248
ip mtu 1446
ip ospf 1 area 0
load-interval 30
qos pre-classify
keepalive 10 3
tunnel source GigabitEthernet0/0
tunnel destination 184.185.X.X
tunnel mode ipsec ipv4
tunnel protection ipsec profile Rogers-VPN
service-policy output Tunnel-to-Rogers
interface Tunnel5
ip address 10.10.20.1 255.255.255.0
no ip redirects
ip mtu 1472
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip tcp adjust-mss 1400
ip ospf 1 area 0
shutdown
keepalive 10 3
tunnel source Loopback0
tunnel mode gre multipoint
tunnel key 50
Spoke Side
interface Tunnel1
bandwidth 2000
bandwidth receive 5000
ip address 10.10.10.2 255.255.255.248
ip mtu 1446
ip ospf 1 area 0
qos pre-classify
keepalive 10 3
tunnel source FastEthernet0/0
tunnel destination 68.3.X.X
tunnel protection ipsec profile Rob-House-VPN
service-policy output Tunnel-to-AZ
interface Tunnel3
description Test
ip address 10.10.20.2 255.255.255.0
no ip redirects
ip mtu 1472
ip nhrp map 10.10.20.1 68.3.102.45
ip nhrp map multicast 68.3.102.45
ip nhrp nhs 10.10.20.1
ip ospf 1 area 0
shutdown
keepalive 10 3
tunnel source 184.185.209.53
tunnel key 50
I guess a better question would be is it possible to have the same router be the 'hub' of more than one tunnel? I only have one IP from my ISP, but would like to terminate different types of tunnels.
I figured it out. I had some static routes stuck that was preventing it from working. The plain GRE tunnels came up when I removed the static routes. What I noticed is that IPSEC doesn't like when the router is using virtual-templates (DVTI) and trying to be a DMVPN hub with ipsec protection at the same time. In other words, the same router can't be a VPN client hub and DMVPN hub. Can anyone confirm that limitation?
