Traceback on 7206 NPE-G1 router
Haris P
Level 4
Level 4
Dear Experts ,
I'm getting below error on 7206VXR (NPE-G1)  with IOS "c7200-js-mz.124-3i.bin".. Any Clues
Mar 10 08:16:10.082: %SYS-2-BADBUFFER: Attempt to use contiguous buffer as scattered src, ptr= 662F04A4, pool= 64CCDCCC
-Process= "<interrupt level>", ipl= 1
-Traceback= 0x606E3654 0x60941328 0x60147294 0x6014B5CC
Mar 10 08:16:39.534: %ALIGN-3-SPURIOUS: Spurious memory access made at 0x60145708  reading 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x60145708 0x6014B5CC 0x0 0x0 0x0 0x0 0x0 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x6183B528 0x60146060 0x6014B5CC 0x0 0x0 0x0 0x0 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x6183B828 0x60146060 0x6014B5CC 0x0 0x0 0x0 0x0 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x6183B88C 0x60146060 0x6014B5CC 0x0 0x0 0x0 0x0 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x601468D0 0x6014B5CC 0x0 0x0 0x0 0x0 0x0 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x601468D4 0x6014B5CC 0x0 0x0 0x0 0x0 0x0 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x6014690C 0x6014B5CC 0x0 0x0 0x0 0x0 0x0 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x60146910 0x6014B5CC 0x0 0x0 0x0 0x0 0x0 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x60146B58 0x6014B5CC 0x0 0x0 0x0 0x0 0x0 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x60146B5C 0x6014B5CC 0x0 0x0 0x0 0x0 0x0 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x60146D88 0x6014B5CC 0x0 0x0 0x0 0x0 0x0 0x0
Mar 10 08:16:39.534: %ALIGN-3-TRACE: -Traceback= 0x6182BE88 0x60146EE8 0x6014B5CC 0x0 0x0 0x0 0x0 0x0
Leo Laohoo
WOOOOOOOOOOOOOOOW!
That's a pretty old IOS.  I'd start thinking about upgrading your IOS.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Tracebacks usually are indicative of some IOS software bug.  Often resolved after upgrading your IOS.
Sruthi Pendam
Hello Haris ,
I have decoded the traceback and see you are running into feature limitation . it is advised to upgrade your IOS and as well in certain cases , it is recommended to upgrade to NPE-G2 as well .
So I would suggest you to upgrade IOS and upgrade to NPE-G2. Hope this helps.
c7200-js-mz.124-3i.symbols.gz read in
Enter hex value: 0x606E3654 0x60941328 0x60147294 0x6014B5CC
0x606E3654:errmsg(0x606e3634)+0x20
0x60941328:c7100_dma_pak_coalesce(0x609412bc)+0x6c
0x60147294:fx1000_rx_interrupt(0x60142474)+0x4e20
0x6014B5CC:fx1000_check_tx(0x6014b5cc)+0x0
Enter hex value:  0x6183B528 0x60146060 0x6014B5CC 0x0 0x0 0x0 0x0 0x0
0x6183B528:cef_preprocess_vlan_pkt(0x6183b4d4)+0x54
0x60146060:fx1000_rx_interrupt(0x60142474)+0x3bec
0x0:__start(0x60008000)+-0x60008000
- Sruthi.
