Showing results forĀ
Search instead forĀ
Did you mean:Ā
PBR&ASA 3560
Stewart Thomas
I have a 3560-48ps running  IPBASE. I am wanting to do some PBR on this device. Will I have to change the Image to the IPservices for this to work.
Here is a description of what I'm trying to do. I have two internet connections connecting to two differnet 5510 ASA's. The two ASA connect to the 3560.
All my internet traffic is going out one ASA. Also on this asa I have a static ip range n for internal servers, this asa is working properly with no probelms.
The second ASA is were I'm having my issues. On the second asa my vpn traffic comes in and works fine. I also have a static ip from the ISP. This range I can not get to work. When I do a Nat translation on the second ASA and  If I  try ping from the ouside world the ping comes in but i do not get a reply. After trouble shooting the issue it seems that i have some asymetric routing. So the ping comes in the second asa and tries to go out the first asa. This is because I have a default route in the 3560 going back to the first ASA. I have this route there for the users to get back to the internet.  So I think the issue can be solved with some PBR in the 3560.
jawad-mukhtar
Level 4
Level 4
What is got from u
Two ISP u have
and you want to spilit traffice to ASA1 and ASA2.
If this is the case
in 3560 U have to do PBR.
ACLA (For Routing Traffic Towards ASA1)
Permit ip 192.168.x.10 any
ACLB  (For Routing Traffice Towards ASA2)
permit ip 192.168.x.20 any
Create Router map
Router-map RM-AB permit 10
match ip address ACLA
set ip next hop (ASA1 interface IP)
Router-map RM-AB permit 20
match ip address ACLb
set ip next hop (ASA2 Interface  IP)
Apply Route map to vlan
int vlan x
ip policy route-map RM-AB
*** Do Rate Helpful Posts***
Jawad
