differrent voltage in line card ws-6704
ngo duyen
I see differrent voltage in line card ws-6704.
Iam afraid of something went wrong with my 6500 switch. two 6500 switch is redundant.
Pls help me.
ngo duyen
could you help me?
Giuseppe Larosa
Hello Duyendaica,
the two WS-6704 are powered at same voltage 42 V  (@42V in the title) they are drawing a different electrical current (7.03 Ampere versus 8.98 Ampere) as a result of this they are using a different amount of power.
How many 10GE ports are active in each module?
With what optics are equipped the different ports?
if you make a show module and you compare the hardware revision are they the same or not?
Are the uptimes of the two chassis comparable ?
Hope to help
Giuseppe
hi Giuseppe,
I can see they use the same number of interface and same hardware revision
about up time:
Switch 1: Core-6509-01 switched to active is 2 weeks, 3 days, 9 hours, 45 minutes
Switch 2: Core-6509-02 switched to active is 2 weeks, 3 days, 9 hours, 52 minutes
here the detail:
------------------------show  module switch 1
show  module
Mod Ports Card Type                              Model              Serial No.
  1    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL1336Y1U0
  2   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     SAL134328MX
  6    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     SAL1335X9CB
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0023.ebf1.c19c to 0023.ebf1.c19f   2.9   12.2(14r)S5  12.2(18)SXF1 Ok
  2  0026.993b.7288 to 0026.993b.7297   4.7   7.2(1)       8.5(0.46)RFW Ok
  6  0024.1499.65b8 to 0024.1499.65bb   5.9   8.5(3)       12.2(18)SXF1 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Distributed Forwarding Card WS-F6700-DFC3B     SAL1337Y8T3  4.8    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3BXL     SAL1335X819  1.11   Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAL1335X7QN  4.0    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  6  Pass
------------------------show  module switch 2
  1    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL1336Y1TM
  2   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     SAL134328KU
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     SAL1336XUQD
  6    2  Supervisor Engine 720 (Hot)            WS-SUP720-3BXL     SAL09306EH9
  1  0023.ebf1.c184 to 0023.ebf1.c187   2.9   12.2(14r)S5  12.2(18)SXF1 Ok
  2  0026.993b.7278 to 0026.993b.7287   4.7   7.2(1)       8.5(0.46)RFW Ok
  5  001f.6c77.57a4 to 001f.6c77.57a7   5.9   8.5(3)       12.2(18)SXF1 Ok
  6  0014.a97d.a114 to 0014.a97d.a117   4.6   8.5(3)       12.2(18)SXF1 Ok
  1  Centralized Forwarding Card WS-F6700-CFC       SAL1336Y31S  4.1    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3BXL     SAL1332VMZ0  1.11   Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAL1336XRT2  4.0    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3BXL     SAL09306EGH  1.10   Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAL09306CRB  2.9    Ok
  1  Pass
  2  Pass
  5  Pass
  6  Pass
==============================show  int status  switch 1
show  int status
Port    Name               Status       Vlan       Duplex  Speed Type
Te1/1   connect to 21-DIS- connected    routed        full    10G 10Gbase-SR
Te1/2   connect to 21-DIS- notconnect   1             full    10G 10Gbase-SR
Te1/3   connect to 21-DC-6 connected    routed        full    10G 10Gbase-SR
Te1/4   connect to 21-DC-6 connected    routed        full    10G 10Gbase-SR
Gi2/1   connect to 21-SW-3 connected    201           full   1000 1000BaseSX
Gi2/2   connect to 21-SW-3 connected    201           full   1000 1000BaseSX
Gi2/3                      notconnect   1             full   1000 1000BaseSX
Gi2/4                      disabled     1             full   1000 1000BaseSX
Gi2/5                      disabled     1             full   1000 1000BaseSX
Gi2/6                      disabled     1             full   1000 1000BaseSX
Gi2/7                      disabled     1             full   1000 1000BaseSX
Gi2/8                      disabled     1             full   1000 1000BaseSX
Gi2/9                      disabled     1             full   1000 1000BaseSX
Gi2/10                     disabled     1             full   1000 1000BaseSX
Gi2/11                     disabled     1             full   1000 No Transceiver
Gi2/12                     disabled     1             full   1000 No Transceiver
Gi2/13                     disabled     1             full   1000 No Transceiver
Gi2/14                     disabled     1             full   1000 No Transceiver
Gi2/15                     disabled     1             full   1000 No Transceiver
Gi2/16                     disabled     1             full   1000 No Transceiver
Gi6/1                      disabled     1             full   1000 No Transceiver
Gi6/2                      disabled     1             full   1000 No Transceiver
====================show  int status  switch 2
show  int status
Te1/2   connect to 21-DIS- connected    routed        full    10G 10Gbase-SR
Gi2/1   connect to 21-SW-3 connected    202           full   1000 1000BaseSX
Gi2/2   connect to 21-GW-3 connected    202           full   1000 1000BaseSX
Gi2/4                      notconnect   1             full   1000 1000BaseSX
Gi2/9                      notconnect   1             full   1000 1000BaseSX
Gi5/1                      disabled     1             full   1000 No Transceiver
Gi5/2                      disabled     1             full   1000 No Transceiver
