Direct tcp port 80 and 443 to proxy server
adilasp01
i have a little problem
like this,,,
i have a network with 3 VLAN :
VLAN 1 (150.100.45.0/24)
VLAN 2 (150.100.46.0/24)
VLAN 3 (150.100.47.0/24)
and i have one proxy server (150.100.45.118) which in VLAN 1
all VLAN connected to Switch and router (topology attached)
How to direct tcp 80 & 443 to proxy server in VLAN 1?
thx
Jon Marshall
Is your proxy server capable of doing WCCP ?
If so you could use WCCP on the router subinterfaces for vlan 2 and 3 and redirect traffic that way.
The other solution would be to try PBR and redirect traffic to the proxy server that way.
Either way a couple of questions about your diagram -
1) are you really using those IPs internally ie. they are all public IPs so unless you own them you must be doing NAT on your router ?
2) your subinterface configurations are for the same vlan and all are marked as native. I suspect this is a typo but can you clarify ?
Jon
