Disable client-route-reflection in iBGP
David Kondicz
I enabled this function in iBGP. After that the primary router started propagate all learned rouer to another neighbour in iBGP that i enabled.
i thing the config was
router BGP 100
     neighbour 192.168.1.10 remote-as 100
     neighbour 192.168.1.10 acivate
     neighbour 192.168.1.10 client-route-reflection
Please how can i disable it?
I tryed next think but not helpd me:
router BGP 100
     no bgp clien-to-client reflection
and tyed too:
router BGP 100
    no neighbour 192.168.1.10 client-route-reflection
I need to disable routes learned from eBGP.
Thanx!
BR
Dave
cadet alain
the command should be: no neighbour 192.168.1.10 route-reflector-client.
But this will only leave the iBGP split-horizon rule in effect: iBGP learned routes won't get propagated to other iBGP neighbours.
Regards.
Alain.
