Disable ESMTP inspection on 871
TRACKLESS
I'm trying to get TLS working on our Exchange 2013 server and I've narrowed it down to our router obfuscating the ESMTP commands exiting our network.  I've seen plenty of examples of disabling ESMTP inspection on ASA devices but not on my 871 ISR.  Currently running 12.4(15).
Relevant config for SMTP:
ip port-map user-smtps port tcp 587 description TLS
class-map type inspect match-all email-service
  match access-group name email-servers
  match class-map email-protocols
class-map type inspect match-any email-protocols
  match protocol smtp extended
  match protocol user-smtps
policy-map type inspect internet-private-pmap
  class type inspect email-service
    inspect
zone security private
zone security internet
zone-pair security internet-private source internet destination private
  service-policy type inspect internet-private-pmap
ip nat inside source static tcp 192.168.100.10 25 interface FastEthernet4 25
ip access-list extended email-servers
  permit ip any host 192.168.100.10
  permit ip host 192.168.100.10 any
How do I disable ESMTP inspection or at least bypass it?
8 Replies 8
to bypass inspection of ESMTP traffic, you need to define two class maps (one inbound and one outbound) and specify the 'pass' action. It would look like this:
class-map type inspect match all PASS_ESMTP_INBOUND
match access-group EMAIL_SERVERS_INBOUND
class-map type inspect match all PASS_ESMTP_OUTBOUND
match access-group EMAIL_SERVERS_OUTBOUND
ip access-list extended EMAIL_SERVERS_INBOUND
ip access-list extended EMAIL_SERVERS_OUTBOUND
policy-map type inspect ESMPT_TRAFFIC
 class PASS_ESMPT_INBOUND
  pass
class class-default
 class PASS_ESMTP_OUTBOUND
  pass
class class-default
Basically change from inspect to pass on the policy-map.  I'm positive I tried that but I'll give it a go and come back. Maybe I didn't apply it in both directions...  Thanks!
So I updated inbound and outbound policy-maps to pass the email-service instead of inspect.
    pass
policy-map type inspect private-internet-pmap
    pass
Result it that nothing can connect... SMTP:25 port appears as Stealth according to GRC Shields Up.  Had to go back to inspect to get email flowing again.
Any other suggestions?
just to be sure, do you also have a zone pair from private to Internet configured ? Can you post the full config of your router ?
Sorry... I do have a zone-pair for the other direction.  Full config attached...
Thanks for taking a look!
try and add the below (in bold) to your inbound and outbound policy maps"
    pass
  class type inspect email-protocols
    pass
    pass
    pass
Hmm.. same result.  I tried putting email-protocols above all else in the policy map as well and it still blocks the port.  Oh well... thanks for trying.  This router is getting a little old anyway... might be time to replace it.
johnd2310
Level 8
Level 8
have you tried changing the policy-map
    inspect
to
    pass
John
**Please rate posts you find helpful**
