Disable SMTP inspection on ISR
frenaud3
We have an ISR4321 router and connecting to an SMTP server on port 25 returns a "220 **********" banner and seems to mess with the traffic. I see instructions on how to disable SMTP fixup on ASA firewalls, but nothing for ISR routers. How do we disable SMTP inspection on an ISR4321 router?
7 Replies 7
balaji.bandi
Since we do not have your configuration, can you post the configuration, by default nothing block. but we can only confirm is this from ISR or from outside ?
BB
See below config. This is from internal (192.168.1.x) trying to connect to external SMTP server
! Last configuration change at 11:45:46 MDT Wed Mar 6 2019 by admin
! NVRAM config last updated at 11:11:11 MDT Wed Mar 6 2019 by admin
version 15.5
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname HBRT01
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
clock timezone MDT -6 0
ip name-server 8.8.8.8 8.8.4.4
ip dhcp excluded-address 192.168.48.1 192.168.50.50
ip dhcp pool PUBLIC
network 192.168.48.0 255.255.248.0
default-router 192.168.50.1
dns-server 8.8.8.8 8.8.4.4
lease 30
subscriber templating
redundancy
mode none
vlan internal allocation policy ascending
lldp run
interface GigabitEthernet0/0/0
no ip address
negotiation auto
interface GigabitEthernet0/0/0.1
description CORP
encapsulation dot1Q 1 native
ip address 192.168.1.1 255.255.252.0
ip nat inside
no ip virtual-reassembly
interface GigabitEthernet0/0/0.50
description PUBLIC
encapsulation dot1Q 50
ip address 192.168.50.1 255.255.248.0
ip nat inside
ip access-group 101 in
interface GigabitEthernet0/0/0.65
description RADIOS
encapsulation dot1Q 65
ip address 10.65.66.254 255.255.255.0
ip nat inside
interface GigabitEthernet0/0/1
ip address 172.16.3.2 255.255.255.252 secondary
ip address XXX.XXX.XXX.XXX 255.255.255.248
ip nat outside
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
no ip nat service sip tcp port 5060
no ip nat service sip udp port 5060
ip nat pool PUBLIC-NAT XXX.XXX.XXX.XXX XXX.XXX.XXX.X netmask 255.255.255.248
ip nat inside source list 50 pool PUBLIC-NAT overload
ip nat inside source list 100 interface GigabitEthernet0/0/1 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0/0/0.1
ip route 0.0.0.0 0.0.0.0 204.57.127.1
ip route 10.0.10.0 255.255.255.0 172.16.3.1
ip route 10.0.11.0 255.255.255.0 172.16.3.1
ip route 10.0.20.0 255.255.255.0 172.16.3.1
ip route 10.0.21.0 255.255.255.0 172.16.3.1
ip route 10.10.10.0 255.255.255.0 172.16.3.1
access-list 50 permit 192.168.48.0 0.0.7.255
access-list 100 deny ip 192.168.0.0 0.0.3.255 10.0.10.0 0.0.0.255
access-list 100 deny ip 192.168.0.0 0.0.3.255 10.0.11.0 0.0.0.255
access-list 100 deny ip 192.168.0.0 0.0.3.255 10.0.20.0 0.0.0.255
access-list 100 deny ip 192.168.0.0 0.0.3.255 10.0.21.0 0.0.0.255
access-list 100 deny ip 192.168.0.0 0.0.3.255 10.10.10.0 0.0.0.255
access-list 100 permit ip 192.168.0.0 0.0.3.255 any
access-list 101 deny ip 192.168.48.0 0.0.7.255 192.168.0.0 0.0.3.255
access-list 101 deny ip 192.168.48.0 0.0.7.255 10.65.66.0 0.0.0.255
access-list 101 permit ip any any
access-list 101 remark BLOCK-INTER-VLAN-ROUTING
snmp-server community public RO enable
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 15
no login
transport input none
ntp server 192.168.1.5
end
as per the config on high level  i do not see you have anything which you have mentioned in the past post.
can you tell in the path what other device connected ?
BB
There is nothing else special connected. The router is connected directly to a switch with a few vLANs on the LAN side and directly to the modem on the WAN side.
We are experiencing symptoms similar to this:
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/113423-asa-esmtp-smtp-inspection.html
This proves that either ISP side ot Far end having issue. so suggest to contact remote end about the issue, so they can make changes as per your requirement if they can.
BB
Alan Ng'ethe
Level 3
Level 3
This could be happening at the remote end. There is nothing in the posted config that would be causing this.
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
what mail/SMTP server are you connecting to ?
