Disappearing EtherChannel
erictabone35
Quick question, and I can't seem to find the answer. Any * represents "priviledged" info. I don't want to break any rules.
On our 6509E, we have an EtherChannel programmed as follows:
interface Port-channel45
description PortChannel to **********
switchport
switchport trunk allowed vlan ***,****
switchport mode trunk
switchport nonegotiate
no ip address
shutdown
spanning-tree portfast trunk
spanning-tree bpduguard enable
end
And the interfaces associated with the etherchannel are as follows:
interface GigabitEthernet3/15
description **********
switchport
no ip address
shutdown
speed 1000
duplex full
no mdix auto
flowcontrol send off
no cdp enable
channel-group 45 mode on
end
interface GigabitEthernet4/15
switchport
no ip addresse
shutdown
speed 1000
duplex full
no mdix auto
no cdp enable
end
When I issue the "show port-channel summary" and "sho run int po45" commands, the port-channel shows up as follows:
#sho etherchannel sum
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
Number of channel-groups in use: 33
Number of aggregators:           33
Group  Port-channel  Protocol    Ports
41     Po41(SU)         -        Gi3/12(P)  Gi4/12(P)
42     Po42(SU)         -        Gi1/12(P)  Gi2/12(P)
43     Po43(SD)         -        Gi3/13(D)  Gi4/13(D)
44     Po44(SD)         -        Gi3/14(D)  Gi4/14(D)
45     Po45(SD)         -        Gi3/15(D)  Gi4/15(D)
46     Po46(SD)         -        Gi3/16(D)  Gi4/16(D)
#sho run int po45
Building configuration...
Current configuration : 318 bytes
switchport
no ip address
shutdown
end
However, when the "sho ip int brief" and the "sho interfaces description" commands are executed, the newly created port-channel does not show up.
#sho ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
Port-channel43             unassigned      YES unset  administratively down down
Port-channel44             unassigned      YES unset  administratively down down
Port-channel46             unassigned      YES unset  administratively down down
Port-channel47             unassigned      YES unset  administratively down down
Port-channel48             unassigned      YES unset  administratively down down
Port-channel49             unassigned      YES unset  administratively down down
#sho interfaces desc
Interface                      Status         Protocol Description
Po43                           admin down     down     PortChannel to **********
Po44                           admin down     down     PortChannel to **********
Po46                           admin down     down     PortChannel to **********
Po47                           admin down     down     PortChannel to **********
Po48                           admin down     down     PortChannel to **********
Po49                           admin down     down     AVAILABLE
We have several port-channels (32 total) that are identically configured (for the most part - allowed vlans and associated interfaces are different).  Do you have any insight as to why the device would omit Port-Channel 45 from the interface brief and interface description show commands while displaying the others?  And will it have an adverse effects on the network?
Thank you!
FYI:
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF12a, RELEASE SOFTWARE (fc1)
Peter Paluch
Hi Brandon,
Your interface Port-channel 45 is currently shutdown. Perhaps this Port-channel must reach its up/up state at least once in order to start showing up as an existing interface. Have you been able to make the Po45 actually be up/up? Was it missing from the listings even then?
In addition, I see you are not using LACP or PAgP. Do you have any specific reason for that?
Best regards,
Peter
Leo Laohoo
speed 1000
duplex full
no mdix auto
Is this a copper link or a fibre optic link?
Y'know what?  Fibre or not, take these lines out.  You'll get into more troubles than not.
