Nexus 7000 MPLS Feature-set - LDP missing
ar
Hi.
I installed mpls feature set in N7K.
I was able to enable feature l3vpn.
Then, I tried enabling feature ldp.
It gave me an error of:
# feature mpls ldp
TRANSPORT_SERVICES_PKG license not installed. ldp feature will be shut down after grace period of approximately 120 day(s).
I dont see any TRANSPORT_SERVICES_PKG in the NX-OS licensing guide.
Howerver, there is LAN_TRANSPORT_SERTICE_PKG. But I believe this is not for LDP.
what other licenses are needed here?
That seems a cosmetic bug.
Look at this bug
CSCtr95031
Enabling MPLS gives warning regarding transport license
Symptom:
Getting the following message when enabling LDP:
TRANSPORT_SERVICES_PKG license not installed. ldp feature will be shut down after grace period of approximately x day(s).
Cosmetic issue.  Only the MPLS license is required for LDP.
Raju
9 Replies 9
mahmoodmkl
Level 7
Level 7
Nexus requires separate license for MPLS which needs to be installed to utilize this feature.
shivjain
This is what exactly missing:-
N7K-MPLS1K9
regards
shivlu jain
Yes I have N7K-MPLS1K9 installed already.
# show licens
MDS20111208204251963.lic:
SERVER this_host ANY
VENDOR cisco
INCREMENT MPLS_PKG cisco 1.0 permanent uncounted \
        VENDOR_STRING=MDS_SWIFTN7K-MPLS1K9= \
        HOSTID=VDH=TBM15217918 \
        NOTICE="201112082042519631 \
        3112J6C0742" SIGN=89A9FA04AE82
# sho license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
MPLS_PKG                      Yes   -   In use Never       -
I was able to load feature l3vpn actually as stated above.
But not LDP.
Just to add, the error is this:
# feature mpls ldp
what is the relation of TRANPORT_SERVICES_PKG to LDP?
Or MPLS/LDP requires NX-OS version higher than 5.2(1)??
anyone know this error?
# feature mpls ldp
Look at this bug
CSCtr95031
Symptom:
Raju
sweet....
thanks...
how did you find that?
I went over the bug toolkit and didnt find this under Nexus 7000 "any" software versions.
Hi Allan
Working in Cisco makes it bit easier to find the bug
Raju
thanks much rajs2.
This issue is resolved in 6.1(2)?
