Display SFP light level on a ISR 1100
Is there a command to see the Rx/Tx light levels from the SFP on a ISR1111-4P?
There is no "sh int gi 0/0/0 transceiver" command
isr1100#show int gi 0/0/0 trans?
% Unrecognized command
isr1100#sh int gi 0/0/0 trans
% Invalid input detected at '^' marker.
running 16.09.02.
The SFP that is plugged in is supporting DOM.
Mark Malone
try something like this below , check show inventory first for the sub slot
sh hw-module subslot 0/0 transceiver 0 idprom
Mark Malone
Thank you very match. The command is "show hw-module subslot 0/0 transceiver 0 status"
ISR1100#show hw-module subslot 0/0 transceiver 0 status
The Transceiver in slot 0 subslot 0 port 0 is enabled.
  Module temperature                        = +41.605 C
  Transceiver Tx supply voltage             = 3288.9 mVolts
  Transceiver Tx bias current               = 21828 uAmps
  Transceiver Tx power                      = -6.3 dBm
  Transceiver Rx optical power              = -9.4 dBm
ah great wasn't to far off :)
