Distribute-list using route-map with Prefix-list not working on OSPF
sarahr202
Level 5
Level 5
Hi everybody,
I am at my wits'end .
Please consider the following example:
R1-12.12.12.1 AREA0--12.12.12.2 R2
We want to achieve following:
Using distribute-list on R2 which references a route-map which then references a prefix-list, block installing R1 's  loopbacks: 11.11.1.0/24,11.11.2.0/24, 11.11.3.0/24, except for loopback  1.1.1.1/32
##R1##
R1 has following loop backs, advertised with network commands in OSPF:
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Loopback1
ip address 11.11.1.1 255.255.255.0
interface Loopback2
ip address 11.11.2.2 255.255.255.0
interface Loopback3
ip address 11.11.3.3 255.255.255.0
R1#show running-config | section ospf
router ospf 1
log-adjacency-changes
network 1.0.0.0 0.255.255.255 area 0
network 11.0.0.0 0.255.255.255 area 0
network 12.12.0.0 0.0.255.255 area 0
##R2##
Below we can see R2  is learning R1's loopbacks:
R2#show ip route ospf
1.0.0.0/32 is subnetted, 1 subnets
O 1.1.1.1 [110/2] via 12.12.12.1, 00:24:27, FastEthernet0/0
11.0.0.0/32 is subnetted, 3 subnets
O 11.11.3.3 [110/2] via 12.12.12.1, 00:24:27, FastEthernet0/0
O 11.11.2.2 [110/2] via 12.12.12.1, 00:24:27, FastEthernet0/0
O 11.11.1.1 [110/2] via 12.12.12.1, 00:24:27, FastEthernet0/0
Next we apply configure distribute-list  to prevent R2 from installing 11.11.1.0/24,11.11.2.0/24, 11.11.3.0/24, except for loopback  1.1.1.1/32
router ospf 1
distribute-list route-map DENY-R1 in
ip prefix-list DENY-R1 seq 10 deny 11.11.0.0/16 le 32
ip prefix-list DENY-R1 seq 20 permit 1.1.1.1/32
route-map DENY-R1 permit 10
match ip address DENY-R1
But it does not have any effect, R2 still has11.11.1.0/24,11.11.2.0/24, 11.11.3.0/24,
What am I missing here?
Thanks and have a great weekend!!
2 Accepted Solutions
Peter Paluch
Hi Sarah,
You have a small but significant omission in your route-map: The line match ip address DENY-R1 references an ACL, not a prefix-list, and because that ACL does not exist, no filtering takes place. The route-map should correctly say:
  match ip address prefix-list DENY-R1
Just as an optimization remark, notice that your prefix-list denies certain prefixes, permits another ones (that do not overlap with the denied ones), and has no permit 0.0.0.0/0 le 32 on its end, meaning that it still acts as "what's not permitted is denied". If the goal of the prefix-list is to permit 1.1.1.1/32 exclusively then a single line would suffice:
ip prefix-list DENY-R1 permit 1.1.1.1/32
If its purpose is to filter out the unwanted prefixes and permit everything else then it could be reworked as follows:
ip prefix-list DENY-R1 deny 11.11.0.0/16 le 32
ip prefix-list DENY-R1 permit 0.0.0.0/0 le 32
Best regards,
Peter
ahmedshoaib
Level 4
Level 4
Hi;
Use distribute-list in without route-map;
router ospf 1
 distribute-list prefix DENY-R1 in
Thanks & Best regards;
Peter Paluch
Hi Sarah,
Best regards,
Peter
Good catch Peter,
Agreed , better to use single command to allow 1.1.1.1/32 rather than 0/0 le 32
Thanks and have a great weekend:)
ahmedshoaib
Level 4
Level 4
Hi;
router ospf 1
