Query regarding local-preference and prepend
donnie
Hi all,
I have 2 mpls circuits each connected to a router meant for my local area network's outgoing traffic.
I like to configure my pair of routers in a active-standby kind of HA, where all incoming/outgoing traffic will go through my primary router CE1. In the event my primary router or the 1st MPLS circuit fails , i expect all incoming/outgoing traffic to go through my secondary router CE2. Pls refer to my attached diagram for more details. Is my configuration below able to achieve what i want? In the event sw1 is down, how will the traffic route? Pls advise. TIA!
1)Primary router(CE1)
Interface GigabitEthernet0/0
description WAN cirucit
ip address 2.2.2.6 255.255.255.252
no ip reditects
no ip unreachables
duplex full
speed 1000
no cdp enable
no mop enabled
Interface GigabitEthernet0/1
description LAN
ip address 192.168.1.2 255.255.255.0
standby 1 ip 192.168.1.1
standby 1 priority 150
standby 1 preempt
duplex auto
speed auto
no cdp enable
no mop enabled
router bgp 12345
bgp log-neighbor-changes
network 192.168.1.0 mask 255.255.255.0
neighbor 2.2.2.5 remote-as 4321
neighbor 2.2.2.5 soft-reconfiguration inbound
neighbor 2.2.2.5 route-map preference in
route-map preference permit 10
set local-preference 200
2)Secondary router(CE2)
ip address 2.2.2.2 255.255.255.252
no ip reditects
no ip unreachables
duplex full
speed 1000
no cdp enable
no mop enabled
description LAN
ip address 192.168.1.3 255.255.255.0
standby 1 preempt
duplex auto
speed auto
no cdp enable
no mop enabled
router bgp 12345
neighbor 2.2.2.5 route-map prepend out
route-map prepend permit 10
set as-path prepend 12345 12345 12345 12345
ahmedshoaib
Level 4
Level 4
Hi;
The configuration is looking fine for BGP primary & secondary link selection. You need to add a l3 link between CE1 & CE2 and run iBGP with next-hop self feature.
Now below are failover scenarios:
  1. Primary MPLS link is down.
Outgoing traffic: Local LAN à CE1 (192.168.1.2) à CE2 (via iBGP link) à MPLS cloud.
Return traffic: MPLS cloud à CE2 à Local LAN (Now here is asymmetric traffic).
Solution: You need to IP SLA and call in HSRP track feature to track the Primary BGP link, once link down traffic automatically shift to CE2 RTR.
  1. Switch-1 down.
Outgoing traffic: Local LAN à CE2 (192.168.1.3) à CE1 (via iBGP link) à MPLS cloud.
Return traffic: reach MPLS cloud à CE1 à CE2 (via iBGP link) à Local LAN
  1. Switch-1 down & Primary MPLS down.
Outgoing traffic: Local LAN à CE2 (192.168.1.3) à MPLS cloud.
Return traffic: reach MPLS cloud à CE2 à Local LAN
 Thanks & Best regards;
