distribution OSPF
dangal.43
what kind of route it will be if i will use redistribute command under ospf and what kind of route it will be if i will use distribute list with route map? will it be external or internal?
royalblues
Level 10
Level 10
When you redistribute into OSPF, the routes are tagged as "External" either type 1 or type 2 default being type 2
Distribute list in OSPF is used for controlling prefixes from being entered into the routing table and not for redistribution
Narayan
HI, [Do Rate all HELPFUL POSTS]
Refer link below for distribute list with route-map:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120limit/120s/120s24/routmap.htm
Using Distribute List with Route-Map statements, will be useful to define a Route-Map to prevent OSPF Routes from being added to the Routing Table.
Refer link below for Eg: OSPF Router redistributing the other Protocols:
http://www.cisco.com/warp/public/105/redist.html#ospf
Do RATE ALL HELPUL POSTS
Best Regards,
Guru Prasad R
Jon Marshall
Routes redistributed into your OSPF process will always be external routes, either type 1 or type 2.
Type 1 = Cost of external route as advertised into the OSPF AS + the internal cost within the OSPF AS.
Type 2 = Just the cost of the external route as advertised into the OSPF AS.
By default the type is 2 but you can change this when you redistribute using the "metric" option.
They would still be external whether you use a distribute list/route-map or not.
Jon
marikakis
Level 7
Level 7
"Redistributing routes into OSPF from other routing protocols or from static will cause these routes to become OSPF external routes."
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094e9e.shtml#t32
Distribute-list out: works on originating ASBR, does not let the externals of this ASBR to be flooded in the network towards other OSPF routers
Distribute-list in: does not let incoming LSA's make it to the routing table
http://www.cisco.com/en/US/tech/tk365/technologies_q_and_a_item09186a0080094704.shtml#q12
Kind Regards,
M.
