DLL issue in connection
Jacob Samuel
HI Friends
I need a kind help. I have a router at HQ 7500 Series. I was connecting to one of our branch router on a Serial interface before. Now we have changed the link and using dedicated DSL link to connect to the branch. The link is terminated on a ZHONE Modem then connect to the PA2-FE-TX port on the Router. on the moem the link is showing up but from the Router i am not able to reach the branch router.
At HQ Router
interface fa 1/1/0
ip addres 172.16.200.37 255.255.255.252
speed auto
duplex auto
At Branch
interface fa 0/1
ip add 172.16.200.38 255.255.255.252
speed auto
duplex auto
running EIGRP protocol between HQ and Branches.
STC (Telco) is saying the link is activatred and up. I am in trouble now, i need your immedaite help please.
Can we use PA2-FE-TX for this purpose.
Thanks and regards
Jacob
paolo bevilacqua
invite telco to prove you that the circut is working, using two laptops connected to the DSL mpdems. After it works this way, it will work for routers.
Yes sure Pb, i will initiate the request for the same and update the forum
thanks and regards
Jacob
Giuseppe Larosa
Hello Jacob,
verify with your provider what kind of DSL links they are giving you.
You might have taken two DSL links and you need to make an IPSec VPN over the internet.
Or have you two SDSL modems in back to back ?
Your current configuration would be fine only for the last scenario.
Have you a DSL based ethernet extender ?
see
http://www.zhone.com/products/point-to-point/
if so try
int f1/1/0
speed 10
duplex full
int f0/1
speed 10
duplex full
Hope to help
Giuseppe
HI Giusee,
Thanks for the valuable information. At HQ the modem is ZHONE. I think the Telco technician was little confused and used a normal Modem (netwconnect modem) at the other end. I will check with the ISP and update.
thanks a lot again..
Jacob
