DLSW Configuration
tarik sayel
i have a router 2911 (c2900-universalk9-mz.SPA.150-1.M4)
i need to implement a datalink switch with another , but my 2911 don't have a CLI for enable the dlsw.
Thanks for help
Sayel
5 Replies 5
Peter Paluch
The DLSw support for 2911 is present in the DATA license set. You will need to activate this license in order to be able to use the DLSw.
What active licenses do you currently have on your router?
Best regards,
Peter
i have : ipbasek9
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      None          None          None
uc            None          None          None
data          None          None          None
i have : ipbasek9
Right. Exactly as Roman has also suggested, you will have to purchase and activate the DATA license on your router before you can use the DLSw feature.
Best regards,
Peter
Roman Rodichev
Level 7
Level 7
You need to have "DATA" license on your 2900 to do DLSW
