DMPVN isakmp authentication issue with PKI out of band certificate.
Kach
Hi all,
I have a DMVPN architecture and I want to use PKI certificate for the authentication.
1- I manually generated the Certificate Signing Requests on the Hub and spokes.
2- I sent the certificate for signing to the CA team by email
3- When I received the signed certificates back by email, I added them on the routers
The problem is that my IPsec tunnel does not come UP. The process stuck in phase 1 ( IKE ).
When I test the preshared key, it works. But when I use the certificates, it does not work.
Did anyone have an idea and can help me?
Here are the debug attached to the post.
PS: I have configured the NTP and it is synchronized.
configuration (only IPSEC part)
HUB_DMVPN
crypto isakmp policy 1
encr 3des
hash md5
group 2
crypto isakmp fragmentation
crypto isakmp aggressive-mode disable
crypto ipsec transform-set TRANSFORM_SET esp-des esp-md5-hmac
mode transport
crypto ipsec fragmentation after-encryption
crypto ipsec profile DMVPN
set transform-set TRANSFORM_SET
SPOKE2
encr 3des
hash md5
group 2
mode transport
Thank you!
balaji.bandi
Thank you Balaji for the feedback. I have checked the links but they did not really help me. My certificates are generated and installed manually for the first establishment of tunnels.
Please can you provide the output of "show crypto pki certificates verbose" command and the full configuration of both routers.
Thank you RJI for your feedback. The devices are using the customer's CA so there is sensitive information I cannot put here.
I am trying to find a way to attached necessary output but nothing compromising the customer.
thank !
Kach!
