Showing results forĀ
Search instead forĀ
Did you mean:Ā
DMVPN-5-CRYPTO_SS:socket is DOWN
R Manjunatha
Level 3
Level 3
The DMVPN tunnel was reset, which caused the BGP session to reset as well. We observed that the DMVPN crypto socket is down. What could be the issue? We suspect it might be related to the ISP, but they have reported no abnormalities in their logs
DMVPN-5-CRYPTO_SS:tunnel 1 :local address xxxxx remote tunnel addressXXXX socket Down
Enes Simnica
hey there. The DMVPN tunnel crypto socket going down suggests a potential issue with the ISP, despite no abnormalities in their logs. Check for intermittent packet loss, routing changes, or subtle connectivity issues by running continuous ping or tracert tests to the ISP gateway or remote peers.
Also (it might be) if NAT is being used on the ISP side or between you and the remote site, it could affect the DMVPN tunnel. The socket down message might be a result of the crypto key exchange being interrupted by NAT inconsistencies.Verify if any changes were made to the NAT configuration by the ISP or local firewall.
-Enes
more Cisco?!
more Gym?!
Enes Simnica
-Enes
more Cisco?!
more Gym?!
balaji.bandi
This may caused different issue underlay.
1. check Layer2 and Layer 3 connection and reachability ?
2. is this only one having issue ?
3. what other logs you see both the side ?, (is the log from head end or branch side ?)
Follow below troubleshooting tips ;'
https://www.cisco.com/c/en/us/support/docs/security/dynamic-multipoint-vpn-dmvpn/111976-dmvpn-troubleshoot-00.html
BB
Socket down' meaning there is issue with IPSec
Try clear crypto ipsec sa and check again
MHM
