Command execution without login? Did my ISR 1111-8P got hacked?
MarkusD
today I found a very strange behaviour in my log files on my Cisco Router ISR 1111-8P.
I executed the command "sh history all" and the output was surprising!
CMD: 'show platform' 15:42:00 CEST Tue Sep 3 2024
CMD: 'show version' 15:42:00 CEST Tue Sep 3 2024
CMD: 'show inventory oid' 15:42:01 CEST Tue Sep 3 2024
CMD: 'show diag all eeprom detail' 15:42:02 CEST Tue Sep 3 2024
CMD: 'show interfaces' 15:42:02 CEST Tue Sep 3 2024
CMD: 'show file systems' 15:42:03 CEST Tue Sep 3 2024
CMD: 'show bootflash: all' 15:42:04 CEST Tue Sep 3 2024
CMD: 'show platform software filesystem bootflash: all' 15:42:04 CEST Tue Sep 3 2024
CMD: 'show data-corruption' 15:42:05 CEST Tue Sep 3 2024
CMD: 'show memory statistics' 15:42:05 CEST Tue Sep 3 2024
CMD: 'show process memory' 15:42:06 CEST Tue Sep 3 2024
CMD: 'show process cpu' 15:42:07 CEST Tue Sep 3 2024
CMD: 'show process cpu history' 15:42:07 CEST Tue Sep 3 2024
CMD: 'show license udi' 15:42:08 CEST Tue Sep 3 2024
CMD: 'show license detail' 15:42:09 CEST Tue Sep 3 2024
CMD: 'show buffers' 15:42:09 CEST Tue Sep 3 2024
Sep 3 13:49:54.299: %SMART_LIC-4-RESERVE_IN_PROGRESS: None License Reservation process must be completed with the 'license smart reservation install' command. Reservation started on Jul 20 09:53:43 2021 CEST
CMD: 'show platform' 15:57:00 CEST Tue Sep 3 2024
CMD: 'show version' 15:57:00 CEST Tue Sep 3 2024
CMD: 'show running-config all' 15:57:01 CEST Tue Sep 3 2024
CMD: 'show startup-config' 15:57:06 CEST Tue Sep 3 2024
CMD: 'show inventory' 15:57:06 CEST Tue Sep 3 2024
In syslog (I am logging to a different server) there is no login via SSH or Webserver mentioned and I have not logged in to the router yesterday.
Is it possible to execute commands on a Cisco router without SSH, Telnet or HTTPS connection?
The SSH port and HTTPS server on non-standard port is available via IPv6 from the internet.
Software running on this device: Cisco IOS XE Software, Version 17.03.05
Configuration (removed all routing stuff):
Current configuration : 14608 bytes
! Last configuration change at 12:22:04 CEST Fri Aug 16 2024 by maxxx
! NVRAM config last updated at 07:26:22 CEST Wed Aug 7 2024 by maxxx
version 17.3
service password-encryption
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
aaa new-model
aaa authorization exec default local if-authenticated
aaa session-id common
ip nbar http-services
login on-success log
no device-tracking logging theft
diagnostic bootup level minimal
username maxxx privilege 15 secret 9 $9$XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
username moxxx privilege 5 secret 9 $9$XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
redundancy
mode none
no ip http server
ip http authentication local
ip http secure-server
ip http secure-port 10443
ip forward-protocol nd
ip ssh time-out 60
ip ssh authentication-retries 2
ip scp server enable
logging trap debugging
logging host ipv6 2001:xx:xx:FFFF::2
ip access-list standard 23
10 permit 192.168.0.0 0.0.255.255
snmp-server community public RO 1
snmp-server community JOHNDOE RO 1
snmp-server location Serverraum
ipv6 access-list HE_INTERNAL_NETWORK
sequence 10 permit ipv6 2001:XXXX:XXXX::/48 any
control-plane
privilege exec level 15 reload
privilege exec level 2 show
banner login ^C
WARNING!! Unauthorized Access Prohibited!!
^C
line con 0
transport input none
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 60 0
logging synchronous
transport preferred none
transport input ssh
line vty 5 868
access-class 23 in
exec-timeout 60 0
logging synchronous
transport input ssh
line vty 869 962
access-class 23 in
exec-timeout 60 0
ipv6 access-class HE_INTERNAL_NETWORK in
logging synchronous
transport input telnet ssh
call-home
contact-email-addr ADMIN@googlemail.com
profile "CiscoTAC-1"
active
destination transport-method http
end
 Any help is appreciated.
11 Replies 11
Giuseppe Larosa
Hello @MarkusD ,
all your vty have
access-class 23 in
the access-list 23 is to be checked
under a range of vty you have:
check this also
about the commands listed have you issued a
show tech-support ?
it is actually resolved in an ordered sequence of commands
Hope to hellp
Giuseppe
access-list 23 and HE_INTERNAL_NETWORK contain only the internal local IP networks.
@MarkusD
 Seems to me that this device is managed by some tool and this tool is running commands on it. Do you have DNAC or Cisco Prime? or any similar tool?  This command could be executed by API on port 830 or even SNMP.
No DNAC or Cisco Prime here.
But I have Observum running which accesses the router via SNMP.
I will disable this as a test. And I will remove the default SNMP community "public". I just saw that it is still in the config.
Probably this is it.  The commands is about something checking the device health, which is meant for management tools. If it was a malicious access we probably would see something else and if it was a trully hacker, we wouldn´t see anything.
Leo Laohoo
conf t
 NO service call-home
end
wr
Hello @Leo Laohoo ,
I had thought of show tech-support but I think you are right the call home will send collected info via HTTP transport protocol but before doing this it has to collect the technical data.
for OP @MarkusD  this is probably the right answer and your router has not been hacked !
Hope to help
Giuseppe
MarkusD
Sorry for the late reply, but I wanted to wait and see if the problem continues to persist after my small configuration changes.
First I removed the SNMP community name “public”, because I found CVE-2017-6742 and thought that could be related to the attack.
no snmp-server community public RO 1
But this did not lead to any improvement:
Then I applied an ACL to the web interface 6 days ago:
ip http access-class ipv4 23
ip http access-class ipv6 DTAG_INTERNAL_NETWORK
Since then there has been silence.
No new command executions.
I really think the web interface allows to execute unprivileged commands without login.
By the way, I haven't changed the call-home setting yet.
show ip http client <<- use this to check if there  any login via http or not
MHM
MarkusD
Just a short update:
The command executions returned after a few days.
So I think it has nothing to do with the web or SNMP server.
I did some further investigation and I think it is the call-home service mentioned by @Leo Laohoo .
When I run the "call-home send alert-group inventory" command, the other commands run immediately afterwards.
CMD: 'call-home send alert-group inventory' 11:01:29 CEST Fri Sep 20 2024
CMD: 'show platform' 11:01:29 CEST Fri Sep 20 2024
CMD: 'show version' 11:01:29 CEST Fri Sep 20 2024
CMD: 'show inventory oid' 11:01:30 CEST Fri Sep 20 2024
CMD: 'show diag all eeprom detail' 11:01:31 CEST Fri Sep 20 2024
CMD: 'show interfaces' 11:01:31 CEST Fri Sep 20 2024
CMD: 'show file systems' 11:01:32 CEST Fri Sep 20 2024
CMD: 'show bootflash: all' 11:01:33 CEST Fri Sep 20 2024
CMD: 'show platform software filesystem bootflash: all' 11:01:33 CEST Fri Sep 20 2024
CMD: 'show data-corruption' 11:01:34 CEST Fri Sep 20 2024
CMD: 'show memory statistics' 11:01:34 CEST Fri Sep 20 2024
CMD: 'show process memory' 11:01:35 CEST Fri Sep 20 2024
CMD: 'show process cpu' 11:01:36 CEST Fri Sep 20 2024
CMD: 'show process cpu history' 11:01:36 CEST Fri Sep 20 2024
CMD: 'show license udi' 11:01:37 CEST Fri Sep 20 2024
CMD: 'show license detail' 11:01:37 CEST Fri Sep 20 2024
CMD: 'show buffers' 11:01:38 CEST Fri Sep 20 2024
CMD: 'sh history all' 11:01:50 CEST Fri Sep 20 2024
Hello @MarkusD ,
thanks for your feedback
it is the call home feature as noted first by @Leo Laohoo and your router is not under attack.
Hope to help
Giuseppe
