DMVPN DUAL HUB SINGLE CLOUD CONFIGURATION EXAMPLE
chuckholley
I am looking for a simple configuration for a dmvpn network running eigrp with two hubs on a single cloud.
Do i just create two nhs entries, nhrp map entries, and two multicast entries on the spoke router tunnel interfaces?  And on the hub routers add a delay on the tunnel interfaces for the one i prefer to be the secondary?
I am looking for confirmation and any other tweaks i need to make. i cant seem to find any examples.
Thanks in advance!!
5 Replies 5
Hello
Try here -
Dual DMVPN
res
Paul
Kind Regards
Paul
Thanks Paul, I have looked over this design guide as this was the fist place i went.  however, i cannot find a configuration example for dual hub/single cloud.
i see the high level design and know you can do it. smiley  but it doesnt show what the configuration would look like...unless i am just reading over it.
Hello Chuckholley, did you ever find a configuration example  for a dmvpn network running eigrp with two hubs on a single cloud?   I am getting ready to deploy this type of configuration and have not found any examples.  The DMVPN design guide shows a diagram of this type of network but no configuration examples.  I think I am just going to test this is my lab and see how it works out.
I know this is an old thread ....
but did anyone have any joy with a config examples?
i have found some bits and pieces nothing nice and tidy. ideally looking for dual hubs with single clound.
Mark
