Bookmark
Subscribe
960
DMVPN HUB and SPOKE HW selection help
Skjalg Eggen
hi!
I'm designing a DMVPN solution for one of our customers.
requirements:
150+ locations
50-100 Mb/s IPSEC throughput combined at the HUBs
Low cost (as allways )
I'm going for a dual HUB dual cloud design with EIGRP.
This is to replace a static ASA to ASA S2S VPN solution.
With the ASA's Throughput is not a problem with 5505's at the locations and 5510's as HUBs.
I'm thinking of a couple of 2951's with Cisco VPN Internal Service Module (VPN ISM) as HUBs and 1800 or 870 as spokes.
Spokes will be on low bandwith 2-8 Mb/s ADSL links.
i  am conserned with throughput limitations on the HUB's though. I've seen some throughput tables with very low throughput for the 2800 series (under 20 Mb/s) with VPN, but those numbers were without the . I cannot find any similar tables for the 2900 series with VPN ISM.
With VPN ISM in place Cisco promises 2-3 times better on board performance
(http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps12202/data_sheet_c78-682436.html)
But I am not certain this that this would be the case.
Does this HW look OK for my requirements, or am I on the wrong track?
Skjalg Eggen
Spokes should be 1900 series or 800 series.
I think you are dead on.
That sounds good
Anybody know of a ipsec througput table for routers with Cisco VPN Internal Service Module (VPN ISM)?
Would be awsome to have in a HW selection phase.
It is kind of weird that it doesnt say anything about this in the specs for routers.
For ASA FW's its always in the specs.
