05-28-2009 08:15 PM - edited 03-04-2019 04:55 AM
I have just completed my WAN Link failover using route-map and NAT works perfectly fine. The problem I now face is when the primary link goes down and backup is active, the DMVPN tunnel that uses the primary link also goes down which is a problem for our VPN connection to a DMVPN spoke sites.
Is there a way to dynamically get the tunnel to switch to the backup link interface?
Below is the config on the HUB router:
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key abc123 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set strong esp-3des esp-md5-hmac
crypto ipsec profile 123abc
set security-association lifetime seconds 120
set transform-set strong
interface Loopback0
description PRIMARY LOOPBACK
ip address x.x.x.1 255.255.255.255
interface Loopback1
description BACKUp LOOPBACK
ip address y.y.y.1 255.255.255.255
interface Tunnel0
description DMVPN_HUB
ip address 172.31.4.1 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp authentication abc123
ip nhrp map multicast dynamic
ip nhrp network-id 1
no clns route-cache
tunnel source Loopback0
tunnel mode gre multipoint
tunnel key 12345
tunnel protection ipsec profile 123abc
interface GigabitEthernet0/0
description PRIMARY WAN LINK
bandwidth 2048
ip address X.X.X.1 255.255.255.252
ip accounting output-packets
ip nat outside
ip virtual-reassembly
ip policy route-map NAT-to-ISP1
no ip mroute-cache
load-interval 30
duplex full
speed 100
media-type rj45
no negotiation auto
no cdp enable
interface GigabitEthernet0/1
description LINK TO SWITCH STACK
no ip address
no ip mroute-cache
load-interval 30
duplex full
speed 100
media-type rj45
negotiation auto
interface GigabitEthernet0/1.500
description SECONDARY WAN LINK
encapsulation dot1Q 500
ip address Y.Y.Y.1 255.255.255.252
ip nat outside
ip policy route-map NAT-to-ISP2
no snmp trap link-status
ip route 0.0.0.0 0.0.0.0 X.X.X.2 name DEFAULT-ROUTE-ISP
ip route 0.0.0.0 0.0.0.0 Y.Y.Y.2 200 name SECONDARY-DEFAULT-ROUTE-ISP
ip route 10.30.4.0 255.255.252.0 172.31.4.2 name 10-ADDRESS-RANGES
ip nat pool bkc x.x.x.252 x.x.x.254 netmask 255.255.255.0
ip nat inside source route-map NAT-to-ISP1 pool bkc overload
ip nat inside source route-map NAT-to-ISP2 interface GigabitEthernet0/1.500 overload
route-map NAT-to-ISP2 permit 10
match ip address NAT_ACL
match interface GigabitEthernet0/1.500
route-map NAT-to-ISP1 permit 10
match interface GigabitEthernet0/0
Network 10.30.4.0 255.255.252.0 via 172.31.4.2 DMVPN spoke end is what I want to reach during the failed primary link to be also routed via backup link.
Solved! Go to Solution.
06-14-2009 08:01 PM
Hi Again,
I actually found this solution:
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a0080211f5c.shtml
Policy Based Routing with the Multiple Tracking Options
The only problem is I'm not running the correct IOS version ((C3825-ADVSECURITYK9-M), Version 12.4(7g)). Does anyone know of alternate solution similar to tracking?
06-15-2009 06:04 AM
If you loose your primary connection, even if the interface on your hub router stays UP, the EIGRP adj inside tunnel 1 will timeout and you should start using the EIGRP routes learned via tunnel 2.
So this case should be covered as well.
Laurent.
06-15-2009 02:30 PM
Hi Laurent,
Yes you are correct. Sorry, I should have been more clearer with my new problem.
I have referring to the Internet Link traffic. This thread has definitely fix the VPN solution. I will start a new thread for the Internet traffic problem.
