DMVPN OSPF hello packet not received
happyelfWong_2
Dear all,
     Wonder if anyone encounter same situation of me.
     I build a Dual Hub Dual DMVPN with OSPF and I observed that the ospf hello packet are not arriving hub from spoke.
     Thus my ospf neighbor periodically up/down while the timer exceeed.
     I tried to add static neighbor on spoke and I observe the hub start receiving ospf hello from spoke but it's still not work.
     My DMVPN & OSPF configuration as below
[Hub1]
interface Tunnel31
ip address 10.231.0.251 255.255.0.0
no ip redirects
ip nhrp map multicast dynamic
ip nhrp map 10.231.0.252 10.100.2.254
ip nhrp map multicast 10.231.0.252
ip nhrp network-id 231
ip nhrp holdtime 600
ip ospf network point-to-multipoint
ip ospf mtu-ignore
ip ospf 1 area 3510
tunnel source GigabitEthernet0/1
tunnel mode gre multipoint
tunnel key 231
tunnel protection ipsec profile DMVPN-1 shared
router ospf 1
router-id 10.0.254.1
area 3510 stub no-summary
area 3520 stub no-summary
area 3600 stub no-summary
redistribute static subnets route-map static->ospf
[Hub2]
interface Tunnel32
ip address 10.232.0.252 255.255.0.0
no ip redirects
ip nhrp map 10.232.0.251 10.100.1.254
ip nhrp map multicast 10.232.0.251
ip nhrp network-id 232
ip ospf mtu-ignore
ip ospf 1 area 3520
tunnel key 232
router ospf 1
router-id 10.0.254.2
[Spoke]
interface Tunnel31
ip address 10.231.64.1 255.255.0.0
no ip redirects
ip nhrp map 10.231.0.251 10.100.1.254
ip nhrp map multicast 10.231.0.251
ip nhrp nhs 10.231.0.251
ip nhrp nhs 10.231.0.252
ip ospf mtu-ignore
ip ospf 1 area 3510
tunnel source GigabitEthernet0/0
tunnel key 231
router ospf 1
router-id 10.0.64.1
neighbor 10.0.254.2 cost 20
neighbor 10.0.254.1
Spoke#sh ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.0.254.2        0   FULL/  -        00:01:34    10.231.0.252    Tunnel31
10.0.254.1        0   FULL/  -        00:01:53    10.231.0.251    Tunnel31
Hub2#sh log | inc 10.0.64.1
*Aug  5 17:58:15: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from FULL to DOWN, Neighbor Down: Dead timer expired
*Aug  5 17:58:26: OSPF-1 HELLO Tu31: Rcv hello from 10.0.64.1 area 3510 10.231.64.1
*Aug  5 17:58:26: OSPF-1 HELLO Tu31: Send immediate hello to nbr 10.0.64.1, src address 10.231.64.1
*Aug  5 17:58:26: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from LOADING to FULL, Loading Done
*Aug  5 18:00:37: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from FULL to DOWN, Neighbor Down: Dead timer expired
*Aug  5 18:00:53: OSPF-1 HELLO Tu31: Rcv hello from 10.0.64.1 area 3510 10.231.64.1
*Aug  5 18:00:53: OSPF-1 HELLO Tu31: Send immediate hello to nbr 10.0.64.1, src address 10.231.64.1
*Aug  5 18:00:53: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from LOADING to FULL, Loading Done
*Aug  5 18:02:55: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from FULL to DOWN, Neighbor Down: Dead timer expired
*Aug  5 18:03:15: OSPF-1 HELLO Tu31: Rcv hello from 10.0.64.1 area 3510 10.231.64.1
*Aug  5 18:03:15: OSPF-1 HELLO Tu31: Send immediate hello to nbr 10.0.64.1, src address 10.231.64.1
*Aug  5 18:03:15: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from LOADING to FULL, Loading Done
*Aug  5 18:05:16: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from FULL to DOWN, Neighbor Down: Dead timer expired
*Aug  5 18:05:40: OSPF-1 HELLO Tu31: Rcv hello from 10.0.64.1 area 3510 10.231.64.1
*Aug  5 18:05:40: OSPF-1 HELLO Tu31: Send immediate hello to nbr 10.0.64.1, src address 10.231.64.1
*Aug  5 18:05:40: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from LOADING to FULL, Loading Done
*Aug  5 18:07:43: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from FULL to DOWN, Neighbor Down: Dead timer expired
*Aug  5 18:08:05: OSPF-1 HELLO Tu31: Rcv hello from 10.0.64.1 area 3510 10.231.64.1
*Aug  5 18:08:05: OSPF-1 HELLO Tu31: Send immediate hello to nbr 10.0.64.1, src address 10.231.64.1
*Aug  5 18:08:05: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from LOADING to FULL, Loading Done
*Aug  5 18:10:07: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from FULL to DOWN, Neighbor Down: Dead timer expired
*Aug  5 18:10:27: OSPF-1 HELLO Tu31: Rcv hello from 10.0.64.1 area 3510 10.231.64.1
*Aug  5 18:10:27: OSPF-1 HELLO Tu31: Send immediate hello to nbr 10.0.64.1, src address 10.231.64.1
*Aug  5 18:10:28: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.64.1 on Tunnel31 from LOADING to FULL, Loading Done
Jose Jara
Level 3
Level 3
Hello Peter,
OSPF Network type point-to-multipoint uses multicasts address 224.0.0.5. You have configured neighbor statements and this would be the case for using OSPF network type point-to-multipoint non-broadcast, so, for this to work with neighbor statements first you should change the network type to point-to-multipoint non-broadcast. However, I would solve the multicast issue, remove the neighbor statements, and maintain the network to point-to-multipoint.
I see that you are doing the multicast mappings to the tunnel addreses, you should do to the physical addresses:
ip nhrp map multicast 10.100.2.254
Best Regards,
Jose.
Jose Jara
Level 3
Level 3
Hello Peter,
Best Regards,
Jose.
happyelfWong_2
Hi Jose,
        Problem solved. Thank you.
